2013 ford edge 20x???
JLBlazin00
Has anyone here thinks about the fuel consumption of the vehicle once the wheel was change?? coz im planning to buy a new set of wheels.. but im concern with the fuel economy of it coz i bought the Ecoboost.. Anyone here has an idea or experience on it???
I still have the "stock" setup, so I don't know directly about the Edge. But the basics remain the same. Keep the wheel/tire combo height the same to retain speedometer/odometer accuracy (and OEM navigation, if you have it). Lighter wheels will mean less rolling resistance, and better mileage/acceleration, but also possibly less "shock" absorption, unless the wheel is smaller and you put on a tire with more sidewall. Don't go smaller than the smallest OEM wheel size, so you retain brake clearance.
Ā
Have you narrowed down your choices for new wheels? Are these going to be full-time, year round, or are you considering a winter set/non-winter set?
If weather gets bad, and you can afford the $ and space for a separate winter setup, by all means do so! Tire diameter may be limited though, at least on TireRack I have not seen > 19" (?) offered. And you may save on a wheel/tire package as well. Overall tire/wheel height should be the same as your non-winter setup or your speedometer/odometer will be off.
