cajuns02 Posted July 7, 2014 Report Share Posted July 7, 2014 I replaced the brake booster on the '07. The brake pedal now will not reach the brake switch.....brake lights stay on. It does not look like the rod ob the booster is adjustable. I borrowed the pic below from another member. It is the same scenario. 1 Quote Link to comment Share on other sites More sharing options...
nwil10 Posted February 6, 2016 Report Share Posted February 6, 2016 (edited) @cajuns02 did you find an answer? Im having the same problem. Edited February 6, 2016 by nwil10 Quote Link to comment Share on other sites More sharing options...
nwil10 Posted February 6, 2016 Report Share Posted February 6, 2016 I replaced the brake booster on the '07. The brake pedal now will not reach the brake switch.....brake lights stay on. It does not look like the rod ob the booster is adjustable. I borrowed the pic below from another member. It is the same scenario. IMAG0471_zps7742307a.jpg Im having the same problem. Did you find an answer? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 6, 2016 Report Share Posted February 6, 2016 Was this precaution taken: NOTICE: Do not press, pull or otherwise move the brake pedal while installing the stoplamp switch. The switch must be installed with the booster push rod attached to the brake pedal and with the brake pedal in the at-rest position. Installing this switch with the brake pedal in any other position will result in incorrect adjustment and may damage the switch. May need to get a new stoplamp switch to fix. 2 Quote Link to comment Share on other sites More sharing options...
accordionfolder Posted August 15, 2020 Report Share Posted August 15, 2020 (edited) Hey guys, I just had to do the brake booster replacement on my mom's 2008 Ford edge and had the same issue with the brake lights staying on. I think removing the switch causes it to adjust. It has a pair of black tabs at the base that spin as you remove it. Removing and reinstalling caused it to engage at a new lower height in my car. It seems fairly durable as I did all of the above for the "do not do" list and it's still functioning. This information is all based on using a fomoco OEM switch, I'm not sure if the aftermarket switches are the same. Edited August 15, 2020 by accordionfolder Quote Link to comment Share on other sites More sharing options...
Jerryrig Posted August 22, 2022 Report Share Posted August 22, 2022 I made a video how to fix this- you don’t even need to remove the switch. Hope it helps https://youtu.be/prIyGMyfSdM 1 1 Quote Link to comment Share on other sites More sharing options...
