Engine Rattle
mcali6301
Heat shields are located on the exhaust manifolds and on the catalytic converters. If you follow the exhaust pipe(s) from back to front up to the engine, you will first encounter the cat shield, then the manifold shield, in that order.
Pretty sure you will have to jack up the Edge and check them from underneath.
Per the 2007 (I know your is a 2011) workshop manual:
INSPECT the exhaust system for loose or missing heat shields or foreign material trapped between the heat shields and the exhaust system components. If any heat shields are loose, INSTALL worm gear clamp 7L5Z-5A231-AA and tighten to 7 Nm (62 lb-in). If the heat shields are missing, INSTALL new heat shields or exhaust system components as necessary. If a rattle, noise or buzz condition persists, INSTALL a new heat shield or component as necessary.
For the exhaust manifold heat shield:
Removal
  1. Remove the LH catalytic converter. For additional information, refer to Section 309-00 .
  1. Remove the LH heated oxygen sensor (HO2S). For additional information, refer to Section 303-14 .
  1. Remove the 3 bolts and the LH exhaust manifold heat shield.
