Power tailgate
tpm419419
Hello all
I noticed my power tailgate on my '13 Edge doesn't beep when opening or closing. My 2011 did. Is there a setting I should check? Also and may not be related but my drivers seat doesn't keep the programmed memory. After several days the seat creeps forward plus if I was to exit the car with it running and get back in I find the seat moved all the way forward
Thanks
Thanks traxii
I had a 2011 before my 2013 so I knew how it should work. I took it to Ford with a seat memory issue. Once they unplugged the seat harness and reconnected it everything seems to be working fine. The tailgate "beep" volume is lower then my previous Edge so I don't know if I just didn't hear it or if in fact the seat had something to do with it
All working fine now
Thanks
