Squeaking from power steering?
2013 sport, have had this problem for almost 15000 miles now and ford has replaced my p/s pump 2 times now. It sounds like a metal on metal squeak at low speeds 25 and under. It will do it mostly if I have the wheel slightly of center or when I'm doing a slight turn. Again sound is best described as a quick squeak like when you have worn brakes. No brakes are applied or rubbing. What can I do if this issue isn't fixed I'm still under warranty. I have video I can email for the mechanics out there, no idea how to post it
