rgigowski Posted June 11, 2014 Report Share Posted June 11, 2014 I have 96k on my Edge now and it's time to change plugs and PCV... both seem straight forward. What plugs do you guys use or recommend. There is a $2.50 rebate on the Autolight irridium plugs that brings the cost down to $4.59 but I also have a supeercharged vehicle and used to put those in and dumped them in favor NGK TR6 plugs at a couple of bucks. Won't work here but is irridium worth it? Also, based on your experiences, is it necessary to change the intake gaskets? These things normally are good but I thought I'd through it out there and see what y'all have done. PCV... there were some thread on this and I am good there but would certainly take any tips if ya got'em. Thanks, Rick Quote Link to comment Share on other sites More sharing options...
akirby Posted June 11, 2014 Report Share Posted June 11, 2014 I would use the factory OEM plugs. Quote Link to comment Share on other sites More sharing options...
autom8r Posted June 11, 2014 Report Share Posted June 11, 2014 Rick: You will find a procedure for plug replacement detailed here: http://www.fordedgeforum.com/topic/8724-sparkplug-replacement-job-info-with-photos/ PCV may also have been discussed somewhere else in this forum too. Good luck. Quote Link to comment Share on other sites More sharing options...
