fishx65 Posted June 3, 2014 Report Share Posted June 3, 2014 2011 with 48,000 miles. Looks like I need about 1 quart to get it up to the Cold fill line. Think it's OK to just add a quart of distilled water? Quote Link to comment Share on other sites More sharing options...
normcloutier Posted June 4, 2014 Report Share Posted June 4, 2014 I wouldn't. You should be able to buy a quart of pre-mix. Or go for an oil change and have them top it up Quote Link to comment Share on other sites More sharing options...
Depiry Posted June 4, 2014 Report Share Posted June 4, 2014 Use only the approved antifreeze by color Quote Link to comment Share on other sites More sharing options...
deledge Posted June 4, 2014 Report Share Posted June 4, 2014 I have the same issue with my 2010 with the same miles. You should maintain the same ratios of water and coolant. On another thread I am looking into the possibility of the water pump starting to go and the coolant is leaving the system via weep hole on the water pump. Quote Link to comment Share on other sites More sharing options...
peterc Posted April 10, 2015 Report Share Posted April 10, 2015 it sounds not normal for 1 qt coolant loss. keep eye on it Quote Link to comment Share on other sites More sharing options...
