normcloutier Posted May 27, 2014 Report Share Posted May 27, 2014 Anyone successfully install the Canadian Tire one in a 13 SEL? I'm at the 2 year mark on my Edge and I would imagine the filter is pretty dirty. Quote Link to comment Share on other sites More sharing options...
cjc96 Posted May 28, 2014 Report Share Posted May 28, 2014 Yes I just did a week ago, took only a few minutes and looked just like the factory filter. Mine was two years old in April and it was very dirty. Quote Link to comment Share on other sites More sharing options...
normcloutier Posted May 28, 2014 Author Report Share Posted May 28, 2014 Does it have any scent to it? I don't want any cover up fragrances. Quote Link to comment Share on other sites More sharing options...
cjc96 Posted May 29, 2014 Report Share Posted May 29, 2014 I haven't detected any thus far. Quote Link to comment Share on other sites More sharing options...
motorking Posted May 30, 2014 Report Share Posted May 30, 2014 Anyone successfully install the Canadian Tire one in a 13 SEL? I'm at the 2 year mark on my Edge and I would imagine the filter is pretty dirty. Norm, I am the tech manager at FRAM. Also happen to own a 2011 Edge Sport. The CAF is very easy to change, takes about five minutes. There is a QR code you can scan on our filter that takes you right to an easy to follow installation video. 1 Quote Link to comment Share on other sites More sharing options...
PrinzII Posted May 30, 2014 Report Share Posted May 30, 2014 I installed one in my 2011 Limited. As stated, it only took a few minutes. Quote Link to comment Share on other sites More sharing options...
normcloutier Posted May 31, 2014 Author Report Share Posted May 31, 2014 Norm, I am the tech manager at FRAM. Also happen to own a 2011 Edge Sport. The CAF is very easy to change, takes about five minutes. There is a QR code you can scan on our filter that takes you right to an easy to follow installation video. Is the video specific to the Edge or just a general overview? Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 31, 2014 Report Share Posted May 31, 2014 Norm, I am the tech manager at FRAM. Also happen to own a 2011 Edge Sport. The CAF is very easy to change, takes about five minutes. There is a QR code you can scan on our filter that takes you right to an easy to follow installation video. Checking the "framfreshbreeze" website, the part number for the Edge is CF10547. But I noticed that in the video, the filter being installed is different than the picture given for CF10547, Check the video at 0:42, the filter looks of different construction compared to the removed OEM filter or pictured CF10547. I don't mean the difference in color (Carbon filter vs. regular), but totally different fins & sides. Also, note that the edge in the video is a 2011+ although the video states its for a 2010. http://www.framfreshbreeze.com/Installation.aspx?yr=2011&me=FORD%20TRUCK&ml=Edge Filter being installed: Removed Filter: Quote Link to comment Share on other sites More sharing options...
normcloutier Posted June 1, 2014 Author Report Share Posted June 1, 2014 Installed the new filter today. I think it took me longer to cue up the video and watch it than to change the filter. Pretty easy stuff. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 1, 2014 Report Share Posted June 1, 2014 Installed the new filter today. I think it took me longer to cue up the video and watch it than to change the filter. Pretty easy stuff. Did you get the Fram filter? Did it look like the one in their video? See my post above. Quote Link to comment Share on other sites More sharing options...
normcloutier Posted June 2, 2014 Author Report Share Posted June 2, 2014 Yes I installed the Fram fresh breeze. It was the same as the OEM. Flat corrugated one, not the box looking one. 1 Quote Link to comment Share on other sites More sharing options...
normcloutier Posted June 3, 2014 Author Report Share Posted June 3, 2014 I find the Fram filter very restrictive. So much in fact that it's like losing 2 or 3 settings on the fan speed. For example, on MFT I have 7 lines showing fan speed. 1 is low and 7 is full speed. Full speed only moves about as much air as setting 4 or 5 did with the old filter. I will be switching back. Fan noise is too high in order to get same airflow as before. 2 day old Fram filter for sale? Quote Link to comment Share on other sites More sharing options...
Eatinitup Posted June 5, 2014 Report Share Posted June 5, 2014 ^ Had the exact same issue.. My 07' OEM filter is a plastic frame with wire mesh as the actual filter.. Actually works pretty well and I frequently clean it.. I switched over to the FRAM and hated it. Air on MAX was the equiv. to Setting 1 or 2 with the new filter.. The first generation Edges have very weak AC systems to begin with, so I couldn't take that big of a hit.. I took it out the next day and put the OEM back in. Quote Link to comment Share on other sites More sharing options...
normcloutier Posted June 6, 2014 Author Report Share Posted June 6, 2014 Picked up an OEM pollen filter from Ford today. I am changing back from the Fram due to air flow restriction. I'll update once the swap is done. Quote Link to comment Share on other sites More sharing options...
ScottnSandy Posted July 29, 2014 Report Share Posted July 29, 2014 What's the best method of cleaning the CAF? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 29, 2014 Report Share Posted July 29, 2014 You can clean the plastic screen if that is what you have. Good ol' dawn and a gentle sponge, air dry. If you have the pleated filter, replace it. Quote Link to comment Share on other sites More sharing options...
