2007 Edge getting a whistling sound from brakes when first starting off
Brett-2007
I'm getting high pitch whistling noisy when I first start my 2007 Ford Edg and have the brake peddle engaged and the transmission is put into reverse. The whistling sound will eventually subside but its continuing to last longer as time pass. The brake peddle doesn't seem to loose pressure .
