Blue smoke
Frisco1522
Three times in the last 2 or 3 months and after sitting a day in the garage, when I started my Edge it put out a pretty sizable blue cloud from the tailpipes. It only does it on rare occasions. I have an appointment tomorrow to leave it at the dealer, but will probably cancel since it's not doing it now. I've even gone as far as to video the starts in case it does it again so I can show the service manager. Nothing.
I have a little over 24K on it, doesn't burn oil, no check engine, runs fine and gets decent mileage. Inside tail pipes are black.
Anybody else had this problem?
Changed the PCV valve since you bought it? If that's stuck open, the smoke could just be some excess oil that was blown into the intake being burned off on startup. Similar issue happened on my old Mazda6. Cheap fix as well. Hopefully it's just something minor like that.
