On my 2011 Ford Edge SEL the high beams come on by itself. Even the car is off no key in sight the come on and off after a few seconds. This started all for sudden this afternoon. I usually have my lights set on automatic but even when I turn everything off completely it still happens. What is the issue?????
Sounds like a combination of a bad headlight switch and turn signal switch. Could be a bad ignition switch as well.
Are any other electronics operative with the key removed? There is a courtesy period of 10 minutes I think with the radio/electronics I think, so after that. Can you switch to low beams with the engine off/key out when the high beams are on?
