I recently had a cracked windshield. I had it replaced with OEM windshield. The part numbers on windshield match so this is a rain sensing windshield. When I got out in the fist rain storm I noticed no rain sensing wipers. I returned to body shop that replaced windshield. They told me they would check in to it for me. Later body shop called and said they checked with Ford and the system would have to be reset .So I went to Ford garage and they tried to reset by disconnecting battery. They were good about it and did not charge me anything. They called Ford and was told I needed to return to person that replaced windshield and they needed to reinstall senser in windshield and maybe replace windshield again. Anyone have a problem like this? Anyone know of a fix for the rain sensing?
OK. Problem is fixed. After taking back to glass shop and taking it to ford garage problem was not fixed. I then got out manual and after research on internet I figured out what problem was. The knob that controls the speed of delay wiper also controls the sensativity of the rain sensing wipers. The person that replaced windshield in the first place must have turned the delay wipers and in turn turned off the rain sensing wipers. I can't believe the people at ford garage did not know how it operates.Anyway the problem is fixed. Set your delayed wipers speed before you start engine and that also sets the rain sensing wipers to on. Thank you the post akirby.
  • 4 years later...
