jbswear Posted April 26, 2014 Report Share Posted April 26, 2014 Hey folks, I am in need of your help. The left rear turn signal/brake light on my '07 Edge doesn't work. The running light *does* work, though. I have a trailer receiver and wiring harness for it installed. The light died before I installed the trailer lighting kit, so I know that isn't the culprit. At one point, both left and right side sockets showed signs of burning, so I replaced them. There are now no signs of burning, but the left turn/brake light doesn't work. I'm assuming it's the connector that the socket plugs into because I can swap the sockets left and right and both will work on the right side and neither work on the left side. I've been hunting all over Google-land but cannot find what I need. Can any of you guys point me in the right direction? It's the connector that has the purple wire connected to it; it's a three-wire connector. Repairing it won't be a problem; I'm handy with a soldering iron...just gotta find it! Quote Link to comment Share on other sites More sharing options...
skoryd Posted August 9, 2014 Report Share Posted August 9, 2014 Any chance that you could unplug it and give us a picture of the inside of it? I may be able to give you a Ford part number for it if so. Quote Link to comment Share on other sites More sharing options...
