Tom Champagne Posted April 13, 2014 Report Share Posted April 13, 2014 Just got my 07 Edge lowered with H&R springs and I love the look and ride. My question is when I turn I hear a creaking sound. So far it's been only when I'm turning and driving real slow. I heard it during a trip to a fast food joint during my wait in line. I haven't had the car aligned yet(will do so on Tues this week),maybe it needs to "break-in". Any thoughts on those who have already lowered their Edges. Quote Link to comment Share on other sites More sharing options...
autom8r Posted April 14, 2014 Report Share Posted April 14, 2014 Tom: My springs were noisy for about a month or so after installation. Eventually, they settle in and the noise goes away. Have fun. Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted April 14, 2014 Author Report Share Posted April 14, 2014 Thanks for the reply...that makes me feel better. Can't wait to put the summer tires on...should look great. Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted May 8, 2014 Author Report Share Posted May 8, 2014 Well it's been a month now and still have the creaking noise. Could the whole assembly be installed improperly? I trust the mechanic that did the install... Quote Link to comment Share on other sites More sharing options...
autom8r Posted May 9, 2014 Report Share Posted May 9, 2014 Tom: There are front springs and rear springs clearly marked with paint, hard to mess that up. Do you get the noise driving over flat surfaces or over bumps? Front or rear? Maybe your bushings need a little lube? The front springs are designed to seat in the "cup" at the bottom of the strut tower, the end of the spring will seat in a pocket there. The top is the same but more of a "profiled washer". Notice they are tapered and there is only one way they can be installed. Did you also align the car after the springs were installed? Mine don't creak anymore. I get occasional bushing noise that I resolve with silicone lubricant. Hope that helps. Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted May 9, 2014 Author Report Share Posted May 9, 2014 The noise comes from turning while going real slow...as if in line at a drive-up window. It doesn't happen when going straight. I had the car aligned 3 days after the drop and the noise appeared immediately. Seems to be coming from the pass side front. Which bushings are you referring to? Thanks for the reply. Quote Link to comment Share on other sites More sharing options...
autom8r Posted May 11, 2014 Report Share Posted May 11, 2014 Tom: Here is a compendium of suspension information for the front-end of your Edge. Information on the struts starts at about page 24, but I wanted you to have a complete picture of what is going on. As you can see, there are a few pivot points there that may require periodic lubrication. If it is more of a groan than a creak and only when you turn the wheel especially when you're not moving, I would check the power steering fluid level in the reservoir. It's odd that the noise only happens while turning at a low speed on smooth pavement. Ford Edge Front Suspension.pdf Quote Link to comment Share on other sites More sharing options...
Hollywood1 Posted July 4, 2014 Report Share Posted July 4, 2014 Try this. Buy a can of waterproof silicone lubricant, take off your front wheels and spray the area where the spring meets the top strut hat where the rubber bushing is (no WD-40 or oil based lube!). Also spray at the bottom where the spring meets the lower strut collar and see if the noise goes away. A little trick you can do is to buy some spiral cable loom, jack up the front to uncompressed the spring, and thread the spiral loom onto the bottom where it meets the lower strut collar. 2 Quote Link to comment Share on other sites More sharing options...
autom8r Posted July 5, 2014 Report Share Posted July 5, 2014 The wire loom is a great idea. Quote Link to comment Share on other sites More sharing options...
Hollywood1 Posted July 5, 2014 Report Share Posted July 5, 2014 Thanks, just little tricks learned from years of mistakes. Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted September 7, 2014 Author Report Share Posted September 7, 2014 After all summer of hearing the creaking,I finally took the car back to the mechanic who did the installation and he had it for a whole day and determined it's the driver side strut bearing cap. I bought new caps(oem Ford)h new shocks when the springs were installed. I'm hoping this will solve the creaking noise for good. He even took the caps apart and greased them,but to no avail. I'm crossing my fingers this time. Quote Link to comment Share on other sites More sharing options...
jwallace410 Posted September 25, 2014 Report Share Posted September 25, 2014 How many miles on the vehicle. Ive got a good bit on mine and im replacing my CV Axle which creaks when turning sharply. If it get progressively worse without the caps working for you, might wanna check on that. Hole ir helps. Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted September 27, 2014 Author Report Share Posted September 27, 2014 Right a 60K. thanks for the info. I'm getting new caps installed in a couple of weeks. Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted October 19, 2014 Author Report Share Posted October 19, 2014 Well the new strut mounts did not solve the creaking issue. I've tried all of your suggestions...I also neglected to say that when I got an alignment after the initial install,I had to get new tie rod ends because of wear(according to the alignment shop). Could these be the culprit? If not,I'm going back to stock and see if the noise goes away. Quote Link to comment Share on other sites More sharing options...
autom8r Posted October 20, 2014 Report Share Posted October 20, 2014 Baffled. I have 45k on my springs and there is no front end noise. My suspension is still tight even with 140k miles. No abnormal tire wear, creaking, groaning, nothing. Must be these silky smooth streets I'm driving on. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 20, 2014 Report Share Posted October 20, 2014 There has been some talk that cleaning & re-lubing the bearings and mounts can resolve the problem. Have the stabilizer bar and control arm bushings been checked? Quote Link to comment Share on other sites More sharing options...
