Front axle nut size
Erica Smith
Do you mean the hub nut? These are the numbers I see for the front halfshafts.
Install the ball joint in the knuckle and install the pinch bolt.
  • Tighten to 55 Nm (41 lb-ft).
Position the stabilizer bar link and install the link nut.
Install a new front wheel hub nut.
  • Tighten to 350 Nm (258 lb-ft).
Edited by WWWPerfA_ZN0W
