Travis Totten Posted April 5, 2014 Report Share Posted April 5, 2014 Hello, This question should be an easy one. I was able to get a hold of some OEM fog/turning. FoMo part numbers BT43-13B220-A & BT43-13B221-A. The dealer was going to give me a wiring diagram, but when I went to get it, I was given the run around. The question is can these lights be used as DRLS? The dealer wants to charge me 130.00 to enable my DRL feature, but I have an SE and I am not sure that is even doable and I am not sure what a fog light is. There are plenty of after market LED wiring harness' w/auto control. Does any one know if the lights and an after market DRL control will do what I want? THANKS!! Quote Link to comment Share on other sites More sharing options...
kc300c Posted April 22, 2014 Report Share Posted April 22, 2014 Hey Travis, the OEM lights you are wanting to use as DRLs are not designed to be used in the daytime. The light output is too low for them to be seen in sunlight. Ford designed them to be used at night as an accent Light. This is why these accent lights are activated by the headlight switch. Only an aftermarket product specifically designed as a DRL will perform this function. Quote Link to comment Share on other sites More sharing options...
rwf78155 Posted August 22, 2014 Report Share Posted August 22, 2014 I did the www.daytimebrightlites.com install on a Saturday afternoon and they are FANTASTIC ! Three times brighter than factory They act as true DRL's Their sales and service is impeccable and as a bonus they have turn signals built in to them 1 Quote Link to comment Share on other sites More sharing options...
