nikos88 Posted March 23, 2014 Report Share Posted March 23, 2014 Hi, My current FOB for my EDge 2011 is broken. I still ahve the keu but the buttons are broken. I need to repalce the FOB. My question si, the OEM version I want to buy from EBAY requires that I match the FCC number. I am not sure what my FCC number is. I know my car was made in Ontarion Canada so my quetsion is, if I buy this OEM FOB from ebay, will I be able to use it for my car. The FOB comes with an uncut key but I have my key from the original broken FOB that came with my car. Can I just repalce the keys? and then just program it? Thanks, Nick Quote Link to comment Share on other sites More sharing options...
ls973800 Posted March 24, 2014 Report Share Posted March 24, 2014 If you look closely on the case of your FOB, you will find several numbers including the FCC number. If it is not on the outside of the case, you may have to open it up and look inside. You could ask the seller where to find yours also. Quote Link to comment Share on other sites More sharing options...
Waldo Posted March 24, 2014 Report Share Posted March 24, 2014 There is no difference between the fobs used on Canadian vehicles vs the American ones. So if it works in the US, it will work in Canada. However if your original fob is broken and you only have one other one, you will likely have to take the new one to a dealer to have it programmed. If your old broken fob works just enough (when placed in the "dock" in the console) and you have another working one, you can program a new one yourself. Quote Link to comment Share on other sites More sharing options...
sajid.ali Posted June 21, 2014 Report Share Posted June 21, 2014 On 3/24/2014 at 12:54 PM, Waldo said: There is no difference between the fobs used on Canadian vehicles vs the American ones. So if it works in the US, it will work in Canada. However if your original fob is broken and you only have one other one, you will likely have to take the new one to a dealer to have it programmed. If your old broken fob works just enough (when placed in the "dock" in the console) and you have another working one, you can program a new one yourself. It also depends on the frequency of the transmitter (keyfob) and receiver (in vehicle) i have a key which donot work due to frequency mismatch. My car is build for 433Mhz frequency. While vehicles sold in US have different frequency, so it better to workout before any purchase. Quote Link to comment Share on other sites More sharing options...
