Different HID configuration and problems. Edit: All problems solved.
My car is 11 Edge SEL and it has DRL and auto light control.
Here are all the configurations that I've tryed.
Configuration 1: 35W TRS kit with CANBUS harnesses. Factory harness -> CANBUS -> ballast.
Problem: Sometime doesn't fire up and DRL flickering. Blow the cars fuse once. Some times have to switch the light off/on to fire the HID.
Configuration 2: 35W TRS kit with factory harnesses. Factory harness -> ballast
Same problems. Blow the fuse again. Sometimes even switch the light off/on can not fire the HID. Have to restart the car to fire it up.
That means the factory harness (at lease the fuse) can NOT handle the HID. Even it's 35W.
Then I order the relay harnesses from the TRS. And still have problems.
Configuration 3: 35W TRS kit with relay harnesses. Factory harness -> Relay trigger. HID powered from battery.
HID always fire up. But DRL doesn't work. Its flickering and then turn off. I can hear the relay buzz loud.
Configuration 4: Factory harness -> CANBUS -> Relay trigger. HID powered from battery.
Same problems as configuration 3. Nothing good nothing worse.
Then I search the internet and lots of perple say I need a capacitor. Still waiting the capacitor and I will post the result after I install the capacitor.
Now I switch the light switch to Auto and use a black tape to cover the light sensor to cheat the car never go to DRL mode. At least I don't get flickering DRL and have all the lghts on instead.
So the result is:
The CANBUS is useless for the Edge.
We do need relay harnesses even for 35W HID.
DRL still have problem. To fix it: Add capacitor (Need comfirm). Ask dealer to switch the DRL to amber light. Or cover the light sensor and set the light to Auto.
Edit:
Good news: All problems soved by add a 2200uF capacitor. The DRL and auto light are all work well. :)
Some tricks:
1. The 4700uF capacitor is too big. It cause the HID fire for about less than decond than shut down. I use two 4700uF capacitors make series connection to make it about 2350uF and it works. I use two 4700uF is just because I don't have 2200uF capacitor in hand. Glad I brought two 4700uF capacitors.
2. The capacitor negative pin can NOT connect to the ground. It must be connected to the factory harnesses negative wire. It doesn't damage your car but it doesn't work. The factory harnesses negative wire is not ground at all.
The TRS capacitor harnesses doesn't work on the Ford Edge. It requires the capacitor negative pin connect to the ground. And I'm not sure if it uses a 2200uF capacitor. I guess the 1100uF capacitor should works as well. But I didn't try it.
Edited by hshang
  • 7 months later...
  • 4 weeks later...
Thanks for the write up on the problem and work around on your HID kit. This should be helpful for those Edge owners who have the TRS kit.
For those looking to add an HID kit to their Edge should also take a look at our HID kit. I developed our kit specifically with the Edge in mind. I found a manufacturer who was willing to produce an HID system that eliminates all of the flickering and false starts that so many universal HID kits seem to have. Our fully digital AC canbus HID ballast assemblies have an integrated capacitors to allow the HID bulbs to fire up without issue especially with the "auto-on" headlight switch setting. For some reason, the auto-on setting causes a slight fluctuation in power to the headlights which can cause the HID ballasts to fail to start. Our ballast circuitry and integrated capacitor compensates for this initial power fluctuation and feeds the appropriate inrush current to our ballasts and lamps. Guaranteed starts every time.
Check out our HID kit here: http://drivebright.com/home/product-category/hid-headlight-replacement-kit/
Edited by kc300c
