mrtwohands Posted March 18, 2014 Report Share Posted March 18, 2014 My brake fluid, coolant, and power steering are all low. Can I simply buy any fluid manufacturer and top them off? Quote Link to comment Share on other sites More sharing options...
mrtwohands Posted March 18, 2014 Author Report Share Posted March 18, 2014 And my washer level is low but I got that one covered lol. Quote Link to comment Share on other sites More sharing options...
akirby Posted March 18, 2014 Report Share Posted March 18, 2014 As long as the fluid meets the spec in the OM, yes. Quote Link to comment Share on other sites More sharing options...
mrtwohands Posted March 19, 2014 Author Report Share Posted March 19, 2014 Awesome. Thank you. So if its ford OEM fluids I should be fine? Quote Link to comment Share on other sites More sharing options...
akirby Posted March 19, 2014 Report Share Posted March 19, 2014 Awesome. Thank you. So if its ford OEM fluids I should be fine? NO! You have to check the owners manual to see what type and spec of fluid each one requires. Even Ford could have multiple versions or specs of a fluid and you have to get the right one for your vehicle. The specs are printed in the OM for a reason - PLEASE read it. Quote Link to comment Share on other sites More sharing options...
Platinum White Posted March 19, 2014 Report Share Posted March 19, 2014 If your brake fluid is low and there are no leaks, check the brake pads. They may be close to needing to be replaced. If you replace the pads the fluid will be back to normal. Quote Link to comment Share on other sites More sharing options...
pjsockett Posted January 2, 2015 Report Share Posted January 2, 2015 My Power Steering fluid is low, can I top it off with any Mercon V ATF or do I need to use Motorcraft if I am just adding to what is already in there? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 2, 2015 Report Share Posted January 2, 2015 (edited) What year Edge? I think 2007-12 Edge was Mercon V and 2013+ is Mercon LV, so check owner's manual to be sure. But any brand PS fluid certified for the right Mercon spec should be fine, don't need to have Motorcraft. If the PS is low and you have a lot of miles on your Edge, be sure to check the system for leaks and the fluid for contamination first. EDITED to update chrono info. Edited January 2, 2015 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
pjsockett Posted January 2, 2015 Report Share Posted January 2, 2015 I have a 2012 SEL with 33,000 miles on it. The manual shows Mercon V for PS and Mercon LV for ATF Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 2, 2015 Report Share Posted January 2, 2015 Should be good to go then! Quote Link to comment Share on other sites More sharing options...
