LED Puddle lights on SE?
I also belong to some F150 forums, so I hope I'm not confusing what I have read. Some owner's have found the wires inside the mirror that didn't come with factory puddle lamps.
You can easily remove your plug on the bottom of the mirror and see if there are any wires there. If you need guidance on how to remove the plug, go to DaytimeBrightLites.com and look at the install pictures or video there. At the top far right of the web site is a click-able Info/Install link.
  • 7 months later...
  • 4 weeks later...
I have only heard of SE mirrors having the removable round cover where the puddle light would be. Can you take a picture of the underside of your mirror and either post it here or email it to me? (info@daytimebrightlites.com). If you have the removeable cover then all you have to do is run two conductor wire (18 gauge or larger) from the inside of the car to the mirror. The negative conductor of the wire you ran would connect to a body ground (there is a bolt under the trim near the driver's side door frame near the foot well. The positive wire would then connect to the dome light power wire. (IMPORTANT: always install an inline fuse on the new puddle light positive power wire just before it connects to the dome light power wire. Use a 3-5 amp fuse.)
Several of my LED puddle light customers have done this and were very happy with their upgrade.
