Bluetooth
Lola
  On 3/3/2014 at 12:37 PM, Lola said:
I am not getting sound when I go bluetooth off my iphone. The screen says it has picked up the signal. .....car problem or iphone problem? suggestions?
Thanks!
When car is set to Bluetooth and you are not hearing anything, First try pressing "play" from your phone. Assuming you are playing from your phone music library. can do the same with Pandora. Start it from the phone. if it doesn't play through the car then Try simply restarting the phone. I had the same problem. re-booted my phone then worked perfectly fine.
