Pat8839 Posted March 1, 2014 Report Share Posted March 1, 2014 Sorry not sure if this is correct place to post, but I recently noticed a rattle sound from underneath my Edge when closing either back door or back end. Sounds like it's coming from near the exhaust. Doesn't sound super crazy but I don't want anything to be loose and me not fix that. Thanks! Quote Link to comment Share on other sites More sharing options...
samf727 Posted March 2, 2014 Report Share Posted March 2, 2014 Just noticed the exact same thing on my 2011 SEL FWD two days ago. Seems metal, and possibly exhaust? my thoughts exactly. Couldn't pinpoint without getting underneath the car. Quote Link to comment Share on other sites More sharing options...
Pat8839 Posted March 3, 2014 Author Report Share Posted March 3, 2014 Mine is a 2013 FWD SEL for what it's worth Quote Link to comment Share on other sites More sharing options...
CinnamonEdge Posted March 3, 2014 Report Share Posted March 3, 2014 I've had this on another car and it was the heat shield touching the exhaust. All I needed to do was push on it so that it was bent a little more out of the way. 1 Quote Link to comment Share on other sites More sharing options...
Pat8839 Posted March 4, 2014 Author Report Share Posted March 4, 2014 Awesome, I will check this out! Thank you for the advice! Quote Link to comment Share on other sites More sharing options...
Larry Posted March 5, 2014 Report Share Posted March 5, 2014 Mine was the right hand exhaust shield. Screws held mine on. I removed a couple screws ,put a small bent in the shield, put screws back in. The bend seemed to take the flex out which caused the rattle. The shield rattled against the bottom of the car 2013 SEL Larry Northern,In Quote Link to comment Share on other sites More sharing options...
Pat8839 Posted March 12, 2014 Author Report Share Posted March 12, 2014 1edge I crawled under mine and found the same thing! How much of a bend did you put in it? Will i damage anything if I do that? Not a huge big deal but a brand new car shouldn't rattle! Quote Link to comment Share on other sites More sharing options...
samf727 Posted March 14, 2014 Report Share Posted March 14, 2014 Does anyone have any pictures or more details on this? Nervous going at my Edge ! Don't want to hurt the beauty! Ha. Quote Link to comment Share on other sites More sharing options...
Larry Posted March 14, 2014 Report Share Posted March 14, 2014 1edge I crawled under mine and found the same thing! How much of a bend did you put in it? Will i damage anything if I do that? Not a huge big deal but a brand new car shouldn't rattle! Just enough to take the flex out of it . You may be able to put enough without unscrewing it?? Sorry no pictures. May see if I can take one? Larry Quote Link to comment Share on other sites More sharing options...
Larry Posted March 15, 2014 Report Share Posted March 15, 2014 Just enough to take the flex out of it . You may be able to put enough without unscrewing it?? Sorry no pictures. May see if I can take one? Larry Well I took a picture of the muffler and shield. Hope you can make it out. Not much room under the car. You could probably just push up or pull down on either the front or rear of the shield enough to take the flex out so it wouldn't rattle. The left shield has a wire loom fastened to it which may keep it from rattling? 1 Quote Link to comment Share on other sites More sharing options...
Pat8839 Posted March 17, 2014 Author Report Share Posted March 17, 2014 iedge, I agree I think that wire loom helps keep the driver side one from rattling. My daughter comments on the noise every time the doors close now! Quote Link to comment Share on other sites More sharing options...
Larry Posted March 17, 2014 Report Share Posted March 17, 2014 Pat8839, The only time I noticed mine rattle was when I closed the rear lift gate. I thought I heard the noise coming from the right side rear. How I made sure what it was. I laid under the car and had someone shut the lift gate. And wala there it was. easy fix.. Larry Northern,In Quote Link to comment Share on other sites More sharing options...
Larry Posted May 9, 2014 Report Share Posted May 9, 2014 New rattle/vibration sound when closing doors or liftgate. Not the exhaust heat shield this time. The plastic shield/cover under the right side of the gas tank. Easy fix. I used a non-porous piece of hard rubber About 1-1/2" long x 1" wide x 1/4" thick. Pulled shield down , slid rubber into the narrowest area. Probably could use smaller or larger piece. Larry Northern, In. Quote Link to comment Share on other sites More sharing options...
