Is TPMS really needed?
Whiteknight08
So im looking online at some different sites selling wheel and tire packages. They try to get you to buy 200.00 worth of tpms stuff. This sensor only tells you if your tire pressure is low, right? So do I REALLY NEED this sensor? Will it just give me an annoying light on my dash if I don't have it? Will the vehicle perform differently if I don't have it.
main thing is if I dont NEED this sensor then I cant justify spending 200.00 on it. The wheel will still work the same as if it did not have it correct?
Thanks in Advance!
If you're just replacing your existing ones then you should be able to just swap the sensors over from the old ones. If these are winter or summer only wheels then the tpms light will stay illuminated but nothing else will happen.
I didn't think new sensors were $200 though - that might be a ripoff. Check around.
I just picked up a brand new set of never installed TPMS sensors from a very reliable seller on eBay. Total cost for the 4 Ford brand sensors which fit many Ford models including the Edge was under $50.00 shipped!
There are deals to be had and it's a small price to pay to keep the safety system intact. Not sure if the light being on would have any affect on my annual state vehicle inspection, but again, I wouldn't deliberately by pass the system anyhow for how inexpensive a set of sensors can be had.
Exactly. The sensors in Edge models 2010 and older were attached to the inner wheel using a band to hold the sensor. Unfortunately, you can not install the newer sensors that fit into the valve stem opening because of a difference in the module and radio frequency that they operate on.
The older band type sensors would have to be installed once the tire is off the wheel, same as if you used the valve stem type. Must be why you are getting some high quotes for new sensors. You need the band and the sensor. There are some on eBay, here is a used set of 4 which would fit your Edge regardless of wheel size. $79.95 I only looked at the first few results that came up, may be better deals.
http://www.ebay.com/itm/Ford-OEM-TPMS-Tire-Pressure-Sensors-Bluebanded-SET-Bands-4-Used-/191019145987?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AFord|Model%3AEdge&hash=item2c79a0db03&vxp=mtr
Edited by ls973800
A TPS saved a tire for me. I was driving to work one morning and the TPS came on. Car steered and drove normally so I checked it when I got in the parking lot at work. The RF tire was warmer than the other tires. Pressure on that one was about 22 PSI. Got the trusty 12 volt compressor out and pumped it up. About 3 weeks later same thing happened at the same location on the way to work. same tire was down to about 22 PSI. Pumped it up and went to a tire shop which submerged the wheel and found bubbles. A fine wire was the cause. Tire was repaired and all is fine since. TPS saved me the price of a new tire or two.
My winter wheels don't have them. Funny thing is, the warning light doesn't come on until I've been driving about 20 mins or more. I just acknowledge the warning and can then go back to the regular display for the split window. The icon stays lit but doesn't blink or be otherwise annoying...it's easy to ignore it.
