Jackman5000 Posted February 22, 2014 Report Share Posted February 22, 2014 Hey guys Will 20 inch titanium wheels off of 2014 flex fit my 2012 edge? Bolt pattern matches (4.5) but my current 18,s have 40 mm offset. Will that matter if I buy these new wheels? Apologies for ignorance and Thx for help! Wheels are part number ae9z1007d Quote Link to comment Share on other sites More sharing options...
ls973800 Posted February 25, 2014 Report Share Posted February 25, 2014 The wheel hub bore size on my 2013 Edge was the same size as the Flex wheels I installed. I don't believe the hub bore size has changed but that would be the biggest concern. The offset is no problem. Search the forum in the Wheels section and you will find several posts about the Flex wheels. The 2010 and older Edges have a larger hub bore size than the 2011 and newer models. Here's a link to one discussion about the Flex wheels. Again, I don't know if the 2014 Flex has changed the hub bore size or not. I really doubt it, but can't say for sure. http://www.fordedgeforum.com/topic/13880-2010-2012-flex-rims-on-2011-edge-will-they-fit/ Quote Link to comment Share on other sites More sharing options...
