evh Posted February 18, 2014 Report Share Posted February 18, 2014 My driver's side heat seater stopped working on my 2009 Limited. Anyone replace theirs yet? Do I just remove the leather cover and I can then take off the pad? Is the seat part separate from the back part? Can someone point me to a place on line where I could order the part vs going to the dealer. I googled it and am having trouble finding it. Any advice is welcome. Quote Link to comment Share on other sites More sharing options...
xK317Hx Posted February 19, 2014 Report Share Posted February 19, 2014 In my 2011 the pad is glued to the faom seat cushion. Lower and upper are seperate. I ordered the new lower cushion from here http://fordpartsdiscountoutlet.com/ford/edge-parts/ Quote Link to comment Share on other sites More sharing options...
FordService Posted February 19, 2014 Report Share Posted February 19, 2014 My driver's side heat seater stopped working on my 2009 Limited. Anyone replace theirs yet? Do I just remove the leather cover and I can then take off the pad? Is the seat part separate from the back part? Can someone point me to a place on line where I could order the part vs going to the dealer. I googled it and am having trouble finding it. Any advice is welcome. Hey evh, Check out Ford Parts here. You're able to input your VIN and search the catalog. Let me know if you have questions. Todd Quote Link to comment Share on other sites More sharing options...
evh Posted February 22, 2014 Author Report Share Posted February 22, 2014 xK317Hx, Was it easy to install the new one? Were the steps: - Remove leather cover - Unplug/Remove pad - Install (glue?) new one in place - Plug in - Replace leather cover Does that sound right? Quote Link to comment Share on other sites More sharing options...
akirby Posted February 22, 2014 Report Share Posted February 22, 2014 You have to be careful with the airbags. Quote Link to comment Share on other sites More sharing options...
xK317Hx Posted February 22, 2014 Report Share Posted February 22, 2014 Unplug battery. Unbolt seat from floor. Lean seat back unscrew seat pan. Pop out any cable routers. Unplug green heat pad plug. Pull lower cushion off. Remove leather cover. Replace entire cushion.... It will rip apart of you try and pull the heat pad off. Install new cushion in reverse order. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 22, 2014 Report Share Posted February 22, 2014 (edited) Don't know if unplugging the battery depowers the SRS, but at least on the 2007, the pad is removable according to the manual. Remove the 3 cushion thermal electric device (TED)-to-cushion frame screws.Remove the cushion TED-to-climate control seat cushion adapter screw and remove the TED. Edited February 22, 2014 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
f150bft Posted June 20, 2014 Report Share Posted June 20, 2014 I had to replace one in the 500 we just traded in for our '10 Edge. First thing is to determine which pad in the drivers seat is bad (seat bottom or seat back). Our 500 would not work if either was bad. The first one I put in was the seat back and checked it with an ohm meter. I called our local O'riley parts house and they ordered me what I needed (i think it was 60-65 dollars). Dorman was the company and it turned out that that is who made them for Ford (the original one had the same name on it). About a year later I had to do the seat bottom. It wasn't hard to do, it just took some time. I would recommend you go to a Tractor Supply Co store and buy "hog ring pliers and hog rings". The ones that come with the heating pad are not very good. Quote Link to comment Share on other sites More sharing options...
