memory seat and mirror settings problem
gccch
We have a 2010 MKX. When switching drivers, the memory settings sends the mirror into a continuous drive to one side, as if you are holding the mirror adjustment knob far left or right until it clicks. But it continues to click and does not go to the programmed position. We have tried reprogramming several times.
Is there a way to reset this system?
According to these similar past discussions, you may be needing to replace the mirror motor assembly...
http://www.fordedgeforum.com/topic/12036-side-mirror-memory-position/
http://www.fordedgeforum.com/topic/13410-memory-mirror-not-working-properly/
If you are considering doing it yourself, the method for removing the mirror glass to gain access to the mirror motor is discussed here...
http://www.fordedgeforum.com/topic/4892-how-to-replace-side-mirror/
Good luck!
Edited by Haz
