Idle speed
moataz2812
I believe the correct idle speed is 600 RPM the regular Edge & 640 RPM for the Edge with towing package. Since your in KSA, I think all Edges are equipped with the bigger radiator & cooling fans, so the idle should be 640.
1000 is wrong, take it to the dealer to have them check it out.
Edit: Upon cold startup, the RPM might go higher for a few seconds, but afterwards it should go down to 600 or 640 RPM.
Edited by omar302
Startup for me usually is around 1250-1300 rpm. How long it stays there depends on how long it takes the engine to start warming up. Then it will come down in a stepped fashion to about 600 rpm (no towing for me). Assuming this is all in Park. If you change gears, the rpm's will drop sooner.
Very steady in idle once settled down to 600 rpm. Can hardly see any fluctuations on mine. If you are seeing, you should be hearing the fluctuation too. In that case, might want to look at your idle air control setup.
Edited by WWWPerfA_ZN0W
