normcloutier Posted February 15, 2014 Report Share Posted February 15, 2014 I have aftermarket HID in my 13 SEL and love them. When driving on real rough roads, I can see the light pattern shaking on the road. No issues with that, just curious if this occurs with factory HID or anyone else's aftermarket ones? Quote Link to comment Share on other sites More sharing options...
candurin Posted February 15, 2014 Report Share Posted February 15, 2014 Norm, really the main causes would be loose bulbs (but if I recall you made it quite clear you seated these properly in previous posts), loose o-ring gaskets on the bulb or a loose headlight housing. Is it very drastic? Are you driving on bumpy roads or does it happen on flat, straight roads as well? Quote Link to comment Share on other sites More sharing options...
normcloutier Posted February 15, 2014 Author Report Share Posted February 15, 2014 It only occurs on very bumpy roads. It occurs on both lamps. I'm thinking it's just the electrodes in the bulb moving ever so slightly due to the vehicle shaking. It's pretty subtle. I can see the beam moving a few inches at the far reach of the headlight pattern. I was just wondering if anyone else's shook a little. Quote Link to comment Share on other sites More sharing options...
Limited59 Posted February 15, 2014 Report Share Posted February 15, 2014 I believe both of mine have had some movement of the HID beam on very bumpy roads or over sharp bumps. I always attributed it to the sharpness of these types of lights making the movement more visible. Quote Link to comment Share on other sites More sharing options...
CinnamonEdge Posted February 15, 2014 Report Share Posted February 15, 2014 My OEM HIDs are a tad shaky too. but only on jarring bumps. I agree that it is because you have more of bright cutoff line on the HIDs than halogen. Quote Link to comment Share on other sites More sharing options...
12Edge Posted February 21, 2014 Report Share Posted February 21, 2014 The aftermarket bulb portion is installed in a 9006 style base. depending on how it may have wiggle room and this could be what you are seeing. With the whole vehicle moving I am surprised it is discernible. Quote Link to comment Share on other sites More sharing options...
omar302 Posted February 21, 2014 Report Share Posted February 21, 2014 My MKX with factory HID also shakes a bit on harsh bumps. But since the MKX has adaptive headlights, I thought that was the reason. I guess, as said before, it's probably normal and we are only noticing it because of the sharp cut off. Quote Link to comment Share on other sites More sharing options...
