tpm419419 Posted February 12, 2014 Report Share Posted February 12, 2014 Hello I have a 2013 Edge Limited. The memory positions for my drivers seat will only last a couple of days. Then when starting the car the seat will move fully forward. Also if I place seat where I want it and get out while engine is running and then return, seat moves fully forward. Anyone else have this issue? I have had a 2011 and a 2007 Edge with no issues in this regard I have tried numerous times in resetting the position but nothing helps. Mirrors stay where they should. And yes, I always use the same key fob Thank you Quote Link to comment Share on other sites More sharing options...
teknowiz Posted February 13, 2014 Report Share Posted February 13, 2014 (edited) TSB 11-02-04 might help even though it was for 2011 model. tsb11-02-04.pdf Edited February 13, 2014 by teknowiz Quote Link to comment Share on other sites More sharing options...
tpm419419 Posted February 13, 2014 Author Report Share Posted February 13, 2014 OK Thank you. I just reprogrammed it again. My only question to myself is if I used the keyfob last few times to program it. I'm thinking just maybe I was using the drivers door lock/unlock switch. I'll know for sure in couple of days Quote Link to comment Share on other sites More sharing options...
