Beerhunter Posted February 10, 2014 Report Share Posted February 10, 2014 will there be any problems fitting a 2010 SEL 10 spoke wheel on a 2011 SEL? the 2010 is 18x7.5" while the 2011 is 18x8" with the same bolt pattern as far as i can see. Tirerack list the same aftermarket wheel for both year which should indicate no issues. Thanks Quote Link to comment Share on other sites More sharing options...
akirby Posted February 10, 2014 Report Share Posted February 10, 2014 Should be ok. The bolt pattern and back spacing are the critical measures and if tirerack shows them to be the same they probably are. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 10, 2014 Report Share Posted February 10, 2014 Use an adapter ring to fit the '10 wheel on an '11 hub ('11 hub size is smaller than '10). Quote Link to comment Share on other sites More sharing options...
Beerhunter Posted February 10, 2014 Author Report Share Posted February 10, 2014 Use an adapter ring to fit the '10 wheel on an '11 hub ('11 hub size is smaller than '10). will it not seat w/o the ring? it is a lease return and I dont want to spend a ton on it. Quote Link to comment Share on other sites More sharing options...
ls973800 Posted February 10, 2014 Report Share Posted February 10, 2014 You will not be able to keep the larger hub centered correctly if you don't use some type of hub centric ring like WWPerfA ZNOW mentioned. The cost of four rings can be found for under $10.00. You just need to find the correct size. 2011 and up should have a hub size of around 63.4mm, the 2010 and older around 70.5mm. So you need an ID of 63.4mm and an OD of 70.5mm to fit the larger wheel hubs onto your smaller hubs on the 2011. Check with a supplier to make sure of the sizes I listed. This link shows you what they look like. You may have to contact some of the sellers to find the size you need. http://www.amazon.com/b?ie=UTF8&node=2425144011 Quote Link to comment Share on other sites More sharing options...
akirby Posted February 10, 2014 Report Share Posted February 10, 2014 I forgot about the hubs being different. Quote Link to comment Share on other sites More sharing options...
