Lowery89 Posted January 31, 2014 Report Share Posted January 31, 2014 2013 awd sport, I'm having an issue with just the inside 3-4 inches of the tread worn very noticeably more than the rest of the tire. It's on the front right the most bust shows on all tires. Rotated every oil change, no curbs or alignment issues, toe/camber is set and all just verified no adjustment needed. Tire pressure is 35 and no high speed maneuvers. I also am having the same exact issue with my 2009 focus. I'm at 15000 miles and it looks like I'll only get a few more out of these tires.... WTH? Quote Link to comment Share on other sites More sharing options...
CinnamonEdge Posted January 31, 2014 Report Share Posted January 31, 2014 Do you drive the same exact route everyday? I drove the same route everyday and noticed that I had some pattern wear on my tires. I was taking more rights turns. Stated taking different routes and it helped. Sounds like a camber problem though. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 31, 2014 Report Share Posted January 31, 2014 Who did your alignments? I would go to a different shop to verify. Quote Link to comment Share on other sites More sharing options...
Lowery89 Posted January 31, 2014 Author Report Share Posted January 31, 2014 Same route yes, 12 miles round trip but that just seems crazy to think it's going to do that. My neighbors who I work with don't have the same issue... And a ford dealer did the check know the mechanics personally so I trust the guy. I'm really at a loss Quote Link to comment Share on other sites More sharing options...
CinnamonEdge Posted January 31, 2014 Report Share Posted January 31, 2014 My route is a big circle with big left swinging off ramps. Also fast speeds on ramps can cause bad wear. Yours sounds like bad alignment. I would get it checked out. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 31, 2014 Report Share Posted January 31, 2014 I agree - I think you need a new alignment shop. Quote Link to comment Share on other sites More sharing options...
