full_jingbang Posted January 26, 2014 Report Share Posted January 26, 2014 Today, Since morning, I got the indication of Low Tire Pressure. I checked all the tires, 1 of them was a little less, filled it up. nothing happened, the WARNING is still there. how to get rid of it ? Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 26, 2014 Report Share Posted January 26, 2014 (edited) You need to drive for a while before it goes.a few miles. From the owners manual of a 2011: After inflating your tires to the manufacturers recommended inflation pressure as shown on the Tire Label (located on the edge of drivers door or the B-Pillar), the vehicle must be driven for at least two minutes over 20mph (32km/h) before the light will turn off. Edited January 26, 2014 by omar302 Quote Link to comment Share on other sites More sharing options...
full_jingbang Posted January 26, 2014 Author Report Share Posted January 26, 2014 On 1/26/2014 at 10:20 AM, omar302 said: You need to drive for a while before it goes.a few miles. From the owners manual of a 2011: After inflating your tires to the manufacturers recommended inflation pressure as shown on the Tire Label (located on the edge of drivers door or the B-Pillar), the vehicle must be driven for at least two minutes over 20mph (32km/h) before the light will turn off. I did that, I drove about 10km since the light suddenly turned ON. and another 10km in the afternoon, while going on lunch, then again 10km going back office. but nothing happened.... I was wondering if one of the tire has small leakage and that could be the reason ????? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 26, 2014 Report Share Posted January 26, 2014 On 1/26/2014 at 11:49 AM, full_jingbang said: I was wondering if one of the tire has small leakage and that could be the reason ????? Entirely possible. I assume you filled the "low" tire up to 35 psi? If there is any rust on the wheel rims, that can compromise the tire bonding and needs to be sanded off. Quote Link to comment Share on other sites More sharing options...
wlepse Posted January 26, 2014 Report Share Posted January 26, 2014 Does the spare have a sensor? Just wondering because I switched to another set of wheels without TPMS and I could swear the warning on the dash said TPMS failure, but lately it is saying low pressure. Guess I should pop the deck and double check. Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 26, 2014 Report Share Posted January 26, 2014 The spare does not have a sensor. Quote Link to comment Share on other sites More sharing options...
wlepse Posted January 26, 2014 Report Share Posted January 26, 2014 Wonder why mine is saying low pressure then when there are no sensors to tell the computer it is low. Maybe after X TPMS failure msgs it defaults to low pressure??? Quote Link to comment Share on other sites More sharing options...
full_jingbang Posted January 28, 2014 Author Report Share Posted January 28, 2014 Well, I guess one of the sensor (TPMS) has gone bad. does anyone knows how to check "WHICH ONE" ? and what is the Part Number and its cost ???? Quote Link to comment Share on other sites More sharing options...
ls973800 Posted January 28, 2014 Report Share Posted January 28, 2014 First time I had installed some new wheels with the old sensors put in, the TPMS light on the dash came on. I drove about 10 miles but the light never went out. This was all city driving, with no speeds over about 30-40 MPH or so. I got onto a freeway and hit 60 MPH. Within 1 minute the light went out. Perhaps you need to make sure you have gone over 60 MPH? Quote Link to comment Share on other sites More sharing options...
EdgeGermany Posted January 28, 2014 Report Share Posted January 28, 2014 Hello, I had the same issue. After replacing my front brake discs and pads the warning disappeared. I recommend to check your brakes and replace parts if needed. Best regards, Rene Quote Link to comment Share on other sites More sharing options...
full_jingbang Posted February 3, 2014 Author Report Share Posted February 3, 2014 Just for the info. Yesterday I went to carwash, when the car got cleaned, I parked in office. When I started again to go home, the light was gone. TPMS seems to be OK ..... Quote Link to comment Share on other sites More sharing options...
engops Posted July 1, 2014 Report Share Posted July 1, 2014 2011 Edge for me. Wouldn't it be great if it stated which tire was low? Quote Link to comment Share on other sites More sharing options...
akirby Posted July 1, 2014 Report Share Posted July 1, 2014 On 7/1/2014 at 11:50 AM, engops said: 2011 Edge for me. Wouldn't it be great if it stated which tire was low? Yep. Still not sure why they don't do that since they have the info. Quote Link to comment Share on other sites More sharing options...
nickf1011 Posted July 1, 2014 Report Share Posted July 1, 2014 On 7/1/2014 at 1:32 PM, akirby said: Yep. Still not sure why they don't do that since they have the info. Does the system have that info though? I know some systems can determine it, while others are "dumb" and just get a blanket reading from all the sensors without distinguishing between which is which. At the very least, it would be a nice added feature to put on the MKX. Quote Link to comment Share on other sites More sharing options...
akirby Posted July 1, 2014 Report Share Posted July 1, 2014 On 7/1/2014 at 2:44 PM, nickf1011 said: Does the system have that info though? I know some systems can determine it, while others are "dumb" and just get a blanket reading from all the sensors without distinguishing between which is which. At the very least, it would be a nice added feature to put on the MKX. Yes - according to Ford engineers. They've simply chosen not to display it. Quote Link to comment Share on other sites More sharing options...
