og2711 Posted January 24, 2014 Report Share Posted January 24, 2014 I have a used Ford 2007 Edge SEL. Not long after i purchased it, i took a long 1000 mile trip. On returning, i noticed that when i step on the brakes and turn the steering wheel (at low speeds) such as when making a u-turn, i feel a grinding noise. it's not the end of the world stuff, but i'm more worried it might lead to something bigger Any ideas? Quote Link to comment Share on other sites More sharing options...
akirby Posted January 24, 2014 Report Share Posted January 24, 2014 If it only does it while braking I would suspect the brakes, otherwise I'd check the CV boots and axle and check for any loose suspension parts. Quote Link to comment Share on other sites More sharing options...
munky Posted April 30, 2014 Report Share Posted April 30, 2014 I had same issue. Replaced the front wheel bearings and all is good! Quote Link to comment Share on other sites More sharing options...
Domenico Poiche Davero Posted May 25, 2014 Report Share Posted May 25, 2014 Same problem here. I was told the antilock was causing the noise Quote Link to comment Share on other sites More sharing options...
evh Posted May 25, 2014 Report Share Posted May 25, 2014 Mine was doing that and the pads were gone. It was louder when I turned. Replaced pads and rotors and I am all set. When was the last time you checked your brakes? Quote Link to comment Share on other sites More sharing options...
