kaycamp Posted January 17, 2014 Report Share Posted January 17, 2014 Hey all, hopefully someone can help me out with this one. My windshiled washer pump started running full time and the headlights go dim on one side, with the driving lights on or off, and when i switch to high beams, the other side light gets brighter and the opposite side goes dim and the washer pump runs faster. I think it may be a ground issue, but might also think some type of a module or multifumction relay. I have changed the multifunction switch on the column, but this did not fix anything. Also run a seperate ground from battery to the light grounding system without any change. Any suggestions would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
rgigowski Posted January 17, 2014 Report Share Posted January 17, 2014 Wow... I don't have any idea other than a ground or a module. As for a ground, I hope someone has a wiring diagram for you. Hopefully someone will pipe in soon and help out. Best of luck to you. Quote Link to comment Share on other sites More sharing options...
