Adding automatic headlights to an SE
rcaljr
I have a 2013 Edge SE with manual headlights. I would like to add the automatic feature. My question is if I add the sensor to the top of the dashboard and add the new headlight switch will this work? Or is there more involved? I would appreciate any feedback.
Richie
Hard to say if there is more involved. If you can plug in the new sensor (probably in the SJB) and the switch wiring is the same for both the old and new switch then it might work. Or you might need to get the dealer to update the smart junction box that controls it.
I don't remember anyone else doing it successfully. You can also get an aftermarket kit that will work - it's self-contained.
I follow several Ford F150 forums also, and this question has come up there also. Here is a link from owner's adding it with no problems to a 2011 model. Unfortunately, there are 20 pages and as the new models 2012 and 2013 came out, owner's were not able to do a plug and play to install auto lamps.
The newer models required a trip to the dealer and some vehicle code had to be rewritten or overwritten. If you read through the posts you will see the problems they had to overcome. I don't know how much is comparable with the Edge system, but this might help you.
http://www.f150forum.com/f38/auto-headlight-mod-123905/
If you want to read more, here is another link regarding adding the auto lamps to a F150. Discussion is also about problems if you have DRL's (Daytime running lights from the factory).
http://www.f150forum.com/f38/adding-automatic-headlamps-155873/index3/
  • 3 years later...
