kicker 40css684 component system tweeter locationon door panel
i had a kicker 40css684 component system installed on my 2011 ford edge se.technician said he couldn't find a location for the tweeter on the door panel.no room.so he installed it in the stock spot.i looked in the grill to see where he put the tweeter.i cant see it.the system sounds like shit.i need tweeter mounting options.morel makes tweeter pods but i dont know if they make one that can house a 3/4',20mm tweeter.any help would be usefull.thank you.
Why don't you just install a set of Kicker KS 6x8's and call it a day.. Forget the tweeter! I installed 4 of these KS 6x8's in my Edge along with the Kicker DX 400.4 channel and its loud as hell. Also installed two 12' Kicker L7's in a customer kicker box along with the ZX Kicker Class D 1500.1 Mono Amp. Loudest system i've ever heard, honestly.. Head unit is the Pioneer AVIC Z150BH
thanks for the advice but the 40css684 system is already installed.when i purchased the system from sonicelectronix it had the green check symbol for fitment.i thought there wouldn't be any problem flush mounting the tweeter.i went back online and found this website.www.diymobileaudio.com/cheap,adjustable,easily replaceable tweeter pods.all you need is pvc end caps that fit the tweeters.threaded steel nipples/w hex nuts.bedliner to go over the pvc to make the texture look like the door panels.then spray paint over the tweeter pods with the matching door trim color.the price about $20.00 to $40.00.problem solved!
