trigg Posted January 5, 2014 Report Share Posted January 5, 2014 damn what's up with the abs and snow.. slid right down a hill into a plow bank and some trees. the car wouldn't slow down and couldn't turn. tired to pump them as well and just wouldn't slow down. even on a straight road the car just slides when applying the brakes. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 5, 2014 Report Share Posted January 5, 2014 Why would you think ABS will help you stop on snow? If there's no traction there's no traction and ABS won't help. Snow tires help the most but you still have to drive carefully. Quote Link to comment Share on other sites More sharing options...
sprsnake_wishin Posted January 5, 2014 Report Share Posted January 5, 2014 Ha its called winter. All season tires are no substitution for winter tires. Quote Link to comment Share on other sites More sharing options...
cv27 Posted January 6, 2014 Report Share Posted January 6, 2014 Do you at least feel the vibration of the ABS? Winter, summer or 4 season tires? Quote Link to comment Share on other sites More sharing options...
trigg Posted January 6, 2014 Author Report Share Posted January 6, 2014 been going down that same hill every winter for the past 13 years. Honda accord and a dodge stratus R/T with abs. wife went down the hill right before I did in a highlander. no issue. never had an issue like that. I get this car and there it goes right down like a freakin sled. unreal tires are AS. didtn think I was going to fast BUT maybe I was for what this car would be capable of stopping .now I know. stop at top of hill and ride brake till at bottom. this car is downright risky in the snow you need to give at least 10 yrds for car in front. wow. not good. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 6, 2014 Report Share Posted January 6, 2014 The Edge is considerably heavier than an Accord or a Stratus. Adjust accordingly. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 6, 2014 Report Share Posted January 6, 2014 You mentioned you have 22s with the Sport, right? Not much sidewall action there, even with A/S, not so good. Can you list the specs on your tires? Normally you want narrower tires on smaller wheels for best traction in snow. What tires are on the Highlander? That is comparable in weight to the Edge. I still think you should get better performance from the Edge. I have had no problems on hills/flats with snow/ice etc, but then I also ride the brakes a bit when going downhill, to control speed & increase following distance. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 6, 2014 Report Share Posted January 6, 2014 I forgot about tread width - that's probably another huge difference between the Edge and previous cars. Quote Link to comment Share on other sites More sharing options...
trigg Posted January 7, 2014 Author Report Share Posted January 7, 2014 yeah// there 265's on the 22's. 245's on the highlander. yes, much larger than the 215's on the status. the hill was snow covered very thin but pretty slick underneath. when i came back later in the day i noticed they sanded the freakin thing. Quote Link to comment Share on other sites More sharing options...
trigg Posted January 11, 2014 Author Report Share Posted January 11, 2014 had about an inch of snow on driveway other day on a "slight' incline. I figured I would see if the car can be controlled going down. at the top I engaged the brake and was able to go down slowly. the second I let go of brake to see if it would re-engage the freakin thing slid again with no way to stop it. this can't be normal. must be something wrong with the abs system where it's just unable to get the car to stop. this car is downright dangerous in snow. i'll have them looked at as this is ridiculous. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 12, 2014 Report Share Posted January 12, 2014 It's called ice with wide non-winter tires on a heavy vehicle. Quote Link to comment Share on other sites More sharing options...
BB2010Limited Posted February 14, 2014 Report Share Posted February 14, 2014 (edited) On 1/12/2014 at 12:28 AM, akirby said: It's called ice with wide non-winter tires on a heavy vehicle. On 1/5/2014 at 7:02 PM, sprsnake_wishin said: Ha its called winter. All season tires are no substitution for winter tires. On 1/5/2014 at 6:49 PM, akirby said: Why would you think ABS will help you stop on snow? If there's no traction there's no traction and ABS won't help. Snow tires help the most but you still have to drive carefully. Blaming the driver and the tires is BS. When it happens to you, you'll remember this post. I've personally experienced ths OPs situation a few times in 3 different Fords, once today in fact. I almost went off the side of a mountain. Putting it in PARK saved me and my family. I was actually going for reverse but overshot. Was creeping down a steep winding mountain driveway with fresh snow and chains on the rear tires. The ABS system worked as usual last night and this afternoon. This morning however, there was no braking action, no pump, nothing just rolling down the mountain picking up speed and out of control. There will be no ABS on the way down tomorrow!! Edited February 14, 2014 by akirby Language Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 14, 2014 Report Share Posted February 14, 2014 Sorry to hear about your experience, can definitely be frightening!!! What year & model is your Edge, how many miles? FWD/AWD? Any problems with the brakes before this? I would put chains on all 4 tires, since putting on only 2 gives the Edge unequal purchase on the roadway. 1 Quote Link to comment Share on other sites More sharing options...
