SIRROMMOTORSPORTS Posted January 2, 2014 Report Share Posted January 2, 2014 Many, Including myself have asked or pondered about changing a light bulb or two in our edge with either a different bulb or LED replacement. Here is a quick and easy chart that'll help you out when trying to figure out what bulb number is the correct replacement. Source -- How Many Bulbs Total -- OEM Bulb Number HEADLAMPS -- 2 -- HIR2 or 9012 (Many who choose to change their factory bulb with an aftermarket HID will use a 9006 kit) HID Equipped Model -- 2 -- D3S Front Parking/Turn Signal -- 2 -- 3457 NAK (**Amber**) Rear Turn Signal -- 2 -- 3757 NAK (**Amber**) Stop / Tail / Side Marker -- 4 -- 3157K LCP (or) 3157K Reverse Back Up -- 2 -- 921 License Plate -- 2 -- 168 Interior Map Light -- 2 -- W5W Second Row Dome Light -- 3 -- 578 Rear Courtesy / Trunk -- 1 -- 578 Head Visor Vanity Light -- 1 -- 37 Mirror Puddle Light -- 2 -- 3021 (I replaced mine with 31mm 1210 Festoon Interior Dome White LED for you DIY'ers, or you can order the premades from companies like daytimebrightlites.com, etc...) **ALL BULBS ARE CLEAR IN COLOR UNLESS NOTED** 3 Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 3, 2014 Report Share Posted January 3, 2014 It will amaze you the amount of information available in the owners manual. All Ford vehicles I have seen have had the bulb replacement charts in their owners manual, the oldest for me anyway was a 1989 Grand Marques. But kudos for pointing out the puddle light bulbs, I just don't get why is it a sealed enclosure, while there is a 31mm festoon bulb inside it. Quote Link to comment Share on other sites More sharing options...
akirby Posted January 3, 2014 Report Share Posted January 3, 2014 I'm going to start hiding my valuables in the OM - nobody would ever look there. 1 Quote Link to comment Share on other sites More sharing options...
kc300c Posted January 10, 2014 Report Share Posted January 10, 2014 Thanks for plugging my website SIRROMMOTORSPORTS Quote Link to comment Share on other sites More sharing options...
guidoyanovich Posted January 14, 2014 Report Share Posted January 14, 2014 I'm looking at getting these bulbs to replace the Stop/tail/sidemarker lamp 4 bulbs, 3157K LCP or 3157K per the manual. I have a $70 gift card I need to spend They are from Pepboys but they have can-bus built in. Will these work on our 2013 Edge? thanks all! Pilot 3157 LED Bulb SMD 15 LED Amber 2 PiecePart # IL3157A15 SKU: 867632 Super bright 5050 SMD technology Long life: 50,000 hours of continuous use Instant styling upgrade Direct replacement for almost all factory applications No error messages: Built-in "CAN Bus" LED Pilot 3157 LED Bulb SMD 15 LED Red 2 PiecePart # IL3157R15 SKU: 867625 Super bright 5050 SMD technology Long life: 50,000 hours of continuous use Instant styling upgrade Direct replacement for almost all factory applications No error messages: Built-in "CAN Bus" LED Quote Link to comment Share on other sites More sharing options...
predapio Posted January 23, 2014 Report Share Posted January 23, 2014 No matter what people on here say, I needed the bulb size and it was 6* out. I didn't feel like going outside to check the OM. So thanks for this. Quote Link to comment Share on other sites More sharing options...
dragster13 Posted May 1, 2014 Report Share Posted May 1, 2014 I have factory installed door sill lights, but the Ford dealership says that they can not find a Ford part number for a replacement light. The car has been in the shop for three days trying to replace lamp. Anyone know the part number so these idiots can get this done. Quote Link to comment Share on other sites More sharing options...
candurin Posted May 1, 2014 Report Share Posted May 1, 2014 I don't think you can replace the LED lighting in the sill plate as it is an integrated light strip/array. Is your edge still under warranty? it would be easier for them just to replace the entire illuminated sill plate rather than cut, replace and solder. Quote Link to comment Share on other sites More sharing options...
Fishman2580 Posted March 31, 2017 Report Share Posted March 31, 2017 Sorry to dig up this post again, but dragster13 did you ever find anything with replacing the bulb? My drivers side is currently out. Quote Link to comment Share on other sites More sharing options...
omar302 Posted March 31, 2017 Report Share Posted March 31, 2017 The insert comes as unit, quite expensive: http://m.ebay.com/itm/331887938853 Try to check the wiring & cleaning the connectors, it might be a simple issue. Quote Link to comment Share on other sites More sharing options...
Foxhollow Posted January 24, 2020 Report Share Posted January 24, 2020 You should publish a new bulb chart for newer Edges,,,,say 2015 to 2020. Quote Link to comment Share on other sites More sharing options...
Gadgetjq Posted January 24, 2020 Report Share Posted January 24, 2020 On 1/24/2020 at 7:51 PM, Foxhollow said: You should publish a new bulb chart for newer Edges,,,,say 2015 to 2020. Expand If you're addressing the OP, Sirrommotorsports hasn't posted in this forum since March 2016. It looks like putting together a new bulb chart is on you! Or folks could just check their owner's manuals. 1 Quote Link to comment Share on other sites More sharing options...
Foxhollow Posted January 25, 2020 Report Share Posted January 25, 2020 Hey , Thanks for the suggestion? The owners manual is a car bible, unfortunately my honey had the Edge @ work for the day,,,,,BUT I downloaded the manual online a week b4 mine was delivered so I could familiarize myself with ALL the settings & options. Quote Link to comment Share on other sites More sharing options...
GBB Posted November 3, 2024 Report Share Posted November 3, 2024 Can a single reverse bulb be replaced (burned out) in a 2015 Edge or does the whole unit need to be replaced? Quote Link to comment Share on other sites More sharing options...
1004ron Posted November 3, 2024 Report Share Posted November 3, 2024 On 11/3/2024 at 9:48 PM, GBB said: Can a single reverse bulb be replaced (burned out) in a 2015 Edge or does the whole unit need to be replaced? Expand Welcome. What does it list tin your owners manual? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 1 Report Share Posted March 1 On 11/3/2024 at 9:48 PM, GBB said: Can a single reverse bulb be replaced (burned out) in a 2015 Edge or does the whole unit need to be replaced? Expand Little late, but to answer, the backup lights are LED and can only be replaced as a unit. 1 Quote Link to comment Share on other sites More sharing options...
