I found this excellent Google result regarding the washer pump on the Ford Edge. The one electrical diagram is for a 2008, but it should be the same for your 2007. Just read through the answers at the following link I posted. Make sure your washer fluid isn't frozen.
Fuses mentioned were #45 and #58, but it is believed the wipers themselves wouldn't work also if those were bad. There is a relay in the system which is for the washer.
http://www.justanswer.com/ford/4ekiy-2008-ford-edge-windshield-washer-does-not-work.html
