08 - Blower fan not working w/climate control
rgigowski
I have an 08 Limited I bought used. Great vehicle, very clean and I am impressed with it.
A few months ago I cleaned up the in cab air filter (couldn’t find one locally other than the dealer) and everything worked fine.
A month or so later I noticed the fan wasn’t on no matter what speed I put it on (it has climate control). Started to work on its own during that drive and just forgot about looking at it. Happened a few more times since then and always came on within 10-15 minutes so it was more of a nuisance than a failure.
This past week the car sat at the airport outside parking and now the fan doesn’t come on no matter how long I drive it.
I haven’t looked at anything yet but I am hoping for some advice and guidance before I start looking.
OBTW: Off topic I recently replaced my windshield wipers with Rain-X replacement blades… I highly recommend them. Little pricy but worth it.
Thanks,
Rick
So much for testing it on News Year Eve! hehe
I did though yesterday, sort of. Got in the car and the fan motor is magically back and working. I am going to have to wait until the next time it decides to fail. Not sure what else I can do?
Do have a question though, you mention EATC controller, not sure what that is. Can you give me a better idea?
Thanks!!!
Many blower motors have a module or resistors which allow the blower to operate at different speeds. I think it is different than the ETAC mentioned by Akirby. I have replaced these modules in various other models when the blower hasn't worked, or hasn't worked on all speed settings. Below is what I found in my service manual for my 2013 Edge. I would think your 2008 would have the same, or a similar, component.
Rockauto is showing several blower motor control modules/resistors including Motorcraft brands. Prices range from $40.89 to $97.79. Not sure what the difference between them is, but there are 2 Motorcraft ones with different part numbers and different prices.
Might be something to check. Sorry the pictures didn't attach. I am using a new computer and haven't figured everything out yet. It looked like the speed control is on the left hand side once you remove the glove box.
Blower Motor Speed Control
Removal and Installation
  1. Remove the 2 glove compartment retainer pins.
SDV~us~en~file=N0126559_580.JPG~gen~ref.
  1. Remove the glove compartment.
    1. Detach the glove compartment damper from the glove compartment.
    1. Release the stops by pressing them toward the center of the glove compartment while lowering the glove compartment, and remove the glove compartment.
SDV~us~en~file=N0126558_580.JPG~gen~ref.
  1. Remove the blower motor speed control.
    1. Disconnect the blower motor speed control electrical connector.
    1. Remove the 2 blower motor speed control screws.
SDV~us~en~file=N0126561_580.JPG~gen~ref.
  1. To install, reverse the removal procedure.
Edited by ls973800
Item Part Number Description
1 7806200 Glove compartment damper
2 7806024 Glove compartment
3 — Blower motor speed control screw (2 required)
4 19C603 Blower motor speed control electrical connector
5 19E624 Blower motor speed control (dual-zone electronic automatic temperature control [EATC] vehicles)
5 19A706 Blower motor resistor (electronic manual temperature control [EMTC] vehicles)
1 19C603 Blower motor electrical connector
2 — Blower motor screw (3 required)
3 19805 Blower motor
Edited by WWWPerfA_ZN0W
Great information and THANKS... any chance you can email me the pics? They didn't come through on the post. Not sure if you have access to email addresses or not but I would imagine I can send you a private message with email.
You're in the Dallas are. I am up in Frisco. Not sure if you ever attend the Dallas Cars and Coffee which is this Saturday. I normally do however too many items on the honey do list this week so I will have to pass. Also, my daily driver is an '01 Lightning. Which is why I hit the car show as often as possible.
Edited by rgigowski
Good stuff, thanks!!!
Thank you to WWWPerfA_ZN0W for posting those pictures showing the location of the blower motor control unit. I'm still trying to figure out this new Windows 8 computer and how to do things.
Akirby was correct when he mentioned the EATC as maybe being at fault. This part is described in several different ways, including the listing on Rock Auto as a blower motor control module/resistors. On the pictures posted by WWWperfA_ZNOW, it is called an EATC on the automatic climate control system and an EMTC on the manual climate control system. Might be why there are two different MC part numbers and prices on the Rock Auto listings for the part.
rgigowski, I am over in the Forney area, about 10 miles east of Mesquite. I don't get over to your side of town very often at all. Ever since I sold my 1971 Oldsmobile 442 convertible years ago for extra money towards a down payment on a house, I just haven't been into car shows too much. Maybe some day when it's warmer I can check it out.
Awesome info...
Know the Forney area well.
The house is a good thing... there is always time for car stuff later.
Understand the attachment to the 442. We have a 71 GS convertable that has been in the family since new. My dad bought it my senior year in high school. Today the car is in Florida with my brother.
gbergkamp, not sure on the testing procedure but I was just going to get my volt meter out and start playing until I get an idea what's going on, then post it up for feedback. For me, once the system fails again, I will verify voltage is coming to the fan assy. If that test is negative, then I have a problem upline in the EATC and I don't have the foggiest idea how to test that. My inclination is to just order parts!
However, I haven't gotten to the first test and I totally understand the cold. Tonights low here is 14. Fortunately the blower has been running everyday but the day we came home from the airport which was a week ago today.
I did pull the filter our and make sure there wasn't something obstruction the fan. Oddly, it has been working fine but there wasn't an obstruction so I doubt that has anything to do with it.
Verey frustrating. One time it failed I was driving and hit a pot hole. Dang thing came on right afterwards making me think I have a lose connection. Haven't checked that yet but I have reached under the dash and wiggled anythig I could get my hands on when it failed again and to no avail, nothing.
Very intermittent and frustrating.
Let me know if you see a pattern or stumble on a fix and I will do the same!!
My blower started working again for a little bit and I could hear the fan making a noise, so I replaced the blower motor and everything is working great now. It was nice to come to work with high heat!
Keep me posted on this... mine has yet to fail again since it started working. I suspect it is the blower but more info the better. Good luck and I hope you fixed it once and for all!!!
  • 9 months later...
So my 08 Limited has been experiencing random fan speed or no fan at all and sometimes just works. Would replacing this, 5 19E624 Blower motor speed control (dual-zone electronic automatic temperature control [EATC] vehicles) possibly fix the problem? I don't want to replace it if that's not the problem.
Thanks,
John
  • 2 months later...
Amazing, simply amazing. I have put up with the blower working and not working for almost two years. Whenever it wasn't working I wasn't home where I could text the connections to see if the blower was faulty or if something else like a controller was failing. Finally got tired and ordered a new blower.
OMW... should have done this in the very beginning. Airflow is awesome and the thing is whisper quite. For the lousy 44 bucks, why did I ever jack with this?
