This is the item you want:
AIL-BLK-BRI-EDGE-0710 - 1 set of LH & RH LED Taillight Assembly, 2007-2010 Ford Edge - Shadow Black
as stated on my invoice. Just make sure you put in your note to Dan that you want the ones specific to the 2007 Edge. That's all that's needed, he'll make sure the right parts get out to you.
Send him an email at info@daytimebrightlites.com and he can send you a PayPal invoice to place the order, if you like. Due to the additional cost to manufacture the 07-10 Edge Taillights, the price is a little more than their 2011-14 Edge taillights. Shipping extra.
The taillight will look exactly the same as their current 2011-2014 Edge taillight and is totally plug and play with your stock wire harness. Just unplug your old taillight and plug theirs in. The turn signal function will be different than the current 11-14 Edge taillight. The 07-10 taillight uses the brake lights for the turn signal, just like your stock taillights. So the amber turn signal in the taillight will not be used and the 9 LEDs in their brake light will flash on and off when the turn signals are on.
The reverse light remains unchanged. DTBL does have a reverse bulb offering, also an LED package for the reverse/turn lights.
Edited by WWWPerfA_ZN0W
Exactly! It's more of a habit for me to wish Good Luck to people, to get the best of everything: fast shipping, least trouble, most enjoyment, etc ... :thumbsup:
You'll get the tail lights. The good luck is the small modicum of skill required to replace them properly. It's more a thumbs up type situation than a worry.
