Is there a way to allow the vehicle to choose to use the DRLs and orange turn signals as my choice of DRLs over just the headlights when its daytime? I know there is the selector knob on the dash I can use, but knowing me I'll forget something at some time and have to kick myself later. Just want to leave it on auto so I can let the car choose when its dark enough for the headlights and bright enough for DRLs
Norm, that is interesting. The CD I referenced in the other post where you asked about the wiring guide has a whole section dedicated to reflashing the "as-built" firmware retrieved from the Ford OASIS website and flashed via the proper flashing tools hooked to the cars USB... I forget what the tool was called.
It suggested you could download your specific control module firmwares with your VIN and flash them back to the car. Seems to me that would put it back to stock?!
  • 1 year later...
It is interesting to learn. My car went with a complete set "without DRL", on it there is no RDL safety lock, a blank space there. Whether it means, what I all the same can make active (to switch ON) and program DRL? For example I would like to include and program DRL in a driving beam of headlights when they thus shine in a half of heat of a lamp? It is possible?
Found this article for the F150s, may apply to the Edge also:
http://www.fordf150.net/howto/drl.php
Need to program the SJB to work. From this link:
"This can only be done at a dealer ,,, they have the software to access the your cars computers ,,,,, there should be a section called programable parameters that they will have to go to ,,, and there they will find a section called lighting ,,,,,, then under that they will find a option for turning the DRL on or off (Activate Daytime Running Lamps, for example)"
This is what the FSM says:
Daytime Running Lamps (DRL)
Special Tool(s) Vehicle Communication Module (VCM) and Integrated Diagnostic System (IDS) software with appropriate hardware, or equivalent scan tool
Principles of Operation
NOTE: When installing a new smart junction box (SJB), it must be configured for this feature, if originally equipped. Refer to Section 418-01 .
The SJB controls the DRL by using various inputs to determine whether or not the DRL should be illuminated. These inputs include:
  • Ignition switch position
  • Headlamp switch position
  • Headlamps on or off
  • Transmission gear selection
Inspection and Verification
  1. Verify the customer concern by operating the daytime running lamps (DRL) following these steps:
    • Place the ignition switch in the RUN position.
    • Place the headlamp switch in the OFF position.
    • Place the transmission in any gear other than PARK (P).
    • If the DRL does not operate, make sure the SJB is configured for DRL before proceeding to the next step.
  1. Carry out the continuous and on-demand self tests for the SJB.
    • If any DTCs are retrieved related to the concern, refer to Section 419-10 .
      • If no DTCs are retrieved, go to the next step.
  1. Verify the low beam operation.
    • Place the headlamp switch in the HEADLAMPS ON position.
      • If the low beams do not operate correctly, refer to Headlamps in this section.
      • If the low beams operate correctly and the DRL operation is incorrect, proceed to the next step.
  1. Check the SJB inputs.
    • Monitor the ignition switch, the headlamp switch input PIDs and the transmission gear status PIDs.
      • If the ignition switch PIDs do not agree with the ignition switch position, refer to Section 211-05 .
      • If the transmission gear status PIDs do not agree with the gear selector lever position, refer to Section 307-01 .
      • If the headlamp switch PIDs do not agree with the headlamp switch position, refer to Headlamps in this section.
      • If the PIDs indicate correct ignition, headlamp switch and transmission gear status, install a new SJB. Refer to Section 419-10 . Test the system for normal operation.
Edited by WWWPerfA_ZN0W
