fishx65 Posted December 7, 2013 Report Share Posted December 7, 2013 (edited) 2011 awd sel with 30,000 miles. Dealer did 4 wheel alignment and there are two brand new tires on rear. Vehicle was purchased used with 21,000 miles and two tires were pretty worn. Rides just fine with no vibrations but there is a constant thumping that sounds like it's coming from the right rear. Any ideas?? Edited December 7, 2013 by fishx65 Quote Link to comment Share on other sites More sharing options...
sajid.ali Posted June 19, 2014 Report Share Posted June 19, 2014 2011 awd sel with 30,000 miles. Dealer did 4 wheel alignment and there are two brand new tires on rear. Vehicle was purchased used with 21,000 miles and two tires were pretty worn. Rides just fine with no vibrations but there is a constant thumping that sounds like it's coming from the right rear. Any ideas?? I have the same prob but dealer is unable to figureout Quote Link to comment Share on other sites More sharing options...
fishx65 Posted June 19, 2014 Author Report Share Posted June 19, 2014 This was never solved on my friend's Edge either. He's just living with it. Quote Link to comment Share on other sites More sharing options...
E.A.P Posted July 24, 2014 Report Share Posted July 24, 2014 I have a 2011Ford Edge Limited, and I hear that same thumping sound comimg from the rear left wheel. I triedtaking the wheel of and look for any loose plastic covering, but didn't find anything loose. Quote Link to comment Share on other sites More sharing options...
Shadrack Posted August 13, 2014 Report Share Posted August 13, 2014 Wheel bearing issue maybe? Mine is going in with the same problem. At high speeds, does it howl/growl instead of thump? At say 10-15mph you can hear a thump (very slight) but at hwy speeds mine turns into a growl. Pretty sure it's a wheel bearing issue, there is a TSB out there on this issue I believe. Quote Link to comment Share on other sites More sharing options...
