shadybiz11 Posted December 6, 2013 Report Share Posted December 6, 2013 Hey all, I have a 2009 edge limited that has 91,000 miles on it. about two weeks ago, the transmission started chugging, like it was having a hard time engaging. It happens when your coasting around 40-45 MPH, when you press on the gas to accelerate, it ca-thumps, ca-thumps then accelerates. Anyone know what might be going on with the transmission? Mike Mitchell mike.mitchell@mail.com Quote Link to comment Share on other sites More sharing options...
Terry Loewenberg Posted December 6, 2013 Report Share Posted December 6, 2013 I had a similar issue with a 2008. Turned out to be an individual cylinder coil. It took almost two months to catch it on the dealer diagnostic computer. Quote Link to comment Share on other sites More sharing options...
thirdgenlxi Posted December 6, 2013 Report Share Posted December 6, 2013 Very well may be low on fluid too and neutralizing under lower RPM. You see any leaks anywhere?? I'd check the level just to be sure anyways.... vehicle level, hot, engine idling Quote Link to comment Share on other sites More sharing options...
shadybiz11 Posted December 7, 2013 Author Report Share Posted December 7, 2013 I checked the fluid level. It is either full or not showing up on the dipstick. the little crosschecks are so small it's hard to tell. but I believe it to be full Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 7, 2013 Report Share Posted December 7, 2013 The color of the fluid is lighter than for years past for sure. Use a strong light, and look for the fluid "blob" as viewed at an angle. Quote Link to comment Share on other sites More sharing options...
Larry Posted December 7, 2013 Report Share Posted December 7, 2013 My thought is the tranny is low on fluid. I have a 2013 low mileage Edge so the fluid should be a lighter color than your 09 with 90,000 miles. I can see my fluid level very easily. Just my 2 cents. Larry Northern,In. Quote Link to comment Share on other sites More sharing options...
