electrical trouble
19V is way too high for the alternator output. Should be more like 16V per the workshop manual. What is the battery voltage? See if you can pull the codes first, but this diagnostic path probably applies to you:
DTC P0563 — Charging system voltage was higher than 15.9 volts - CAUSES
  • Bad battery ground
  • High resistance A sense circuit
  • Generator
  • Battery
  • PCM
The diagnostic path listed is quite extensive. I attached a zipped TIF file to illustrate.
The SJB should be checked out by a qualified technician, if it comes to that.
2007 Ford Edge Charging System Test if Generator OverVoltage W.zip
Edited by WWWPerfA_ZN0W
