I lent my Edge to a friend and he must have ran the wipers on a dirty window without using the washer. Wipers must have scraped some grit across the window. There is about a foot long single light scratch on the drivers side near the outer portion of the wiper area. Not that noticeable until you are in the sun then it pops out like a pinstripe. There are a few polishing kits online and I was wondering if anyone used them before? Any Canadian help would be appreciated. Can't always access U.S. products.
I have never had the occasion to polish the glass, but Ceriglass is the name I usually run across on my travels through the web. I don't know if you could get away with cerium oxide powder and high grit sandpaper (wet sanding) on a dremel, if the scratch is really light.
Edited by WWWPerfA_ZN0W
