trockli Posted November 9, 2013 Report Share Posted November 9, 2013 The Ford emblem cam of the front wheel hub of our 2011 Ford EdgeIt has the 20" chrome plastic wheels.Ford says, it is not covered under warranty. Does anyone know the part number or other fix? Quote Link to comment Share on other sites More sharing options...
ls973800 Posted November 9, 2013 Report Share Posted November 9, 2013 (edited) Did you mean to say the emblem came off the wheel? If so, you can find replacements on eBay pretty easily. Those caps are usually pretty tight and are hard to get off even if you are trying. Here is just one listing found that might give you a direction to go in. http://www.ebay.com/itm/ford-center-caps-explorer-mustang-ranger-edge-flex-silver-caps-escape-taurus-/271298794806?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f2aab1536&vxp=mtr I don't know the part number off hand. You can look on the back of one of your other ones to find it. Edited November 9, 2013 by ls973800 Quote Link to comment Share on other sites More sharing options...
trockli Posted November 9, 2013 Author Report Share Posted November 9, 2013 Yes, just the oval blue Ford emblem in the center cap. It seems glued in. I could not find a replacement sticker so far. That would be the easiest fix. Sounds like if I replace the hub cap I will need to remove the wheel. Quote Link to comment Share on other sites More sharing options...
ls973800 Posted November 9, 2013 Report Share Posted November 9, 2013 Here's just emblem stickers for the center caps as found on eBay. For as tight as the center caps are on the wheels, I just take them off to prevent damage by pushing from the back, once the wheel is removed. http://www.ebay.com/sch/i.html?_trksid=p2047675.m570.l2632.R2.TR2.TRC1.A0.Xford+center+cap+sticker&_nkw=ford+center+cap+sticker&_sacat=6030&_from=R40 Quote Link to comment Share on other sites More sharing options...
