Tom Champagne Posted November 3, 2013 Report Share Posted November 3, 2013 My wife's 07 Edge SEL 's driver side mirror is not moving to pre-set position using the controls on the driver's door. When I use her car(I am set for #2 position)the mirror goes up like it's looking at the sky. When she uses it, the mirror looks way out beyond the body line of the car. The seat works fine. Unless I'm not setting the pre-sets properly. Anyone else have this problem? Thanks for any info. Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted November 4, 2013 Report Share Posted November 4, 2013 Set the mirror and seats for driver #1, then press and hold button #1 until you hear one beep, followed by another one, shortly after the 1st one. Then repeat for Driver 2m only holding button 2, for the same procedure. This should be outlined in your owners manual. If the problem still persists, then I would say that you do have a problem, will need the dealer to check it out Quote Link to comment Share on other sites More sharing options...
thirdgenlxi Posted November 4, 2013 Report Share Posted November 4, 2013 It's usually the potentiometers in the mirror motors go bad.... the mirror has absolutely no idea where it actually is, so it just goes in some random direction as far as it can then ratchets 1 Quote Link to comment Share on other sites More sharing options...
11edgelimited Posted November 7, 2013 Report Share Posted November 7, 2013 I had this same problem except the mirror would try to keep going and it would click. Well it lasted a week or so and died. You could still manually move and it would shimmy and shake while moving, but the memory part didn't work it was on the passenger mirror. My 11 edge only has 33,000 miles on it though. I took it in and had to argue with the moron tech at the dealership and finally got him to replace it. Well it went in to get done and the moron broke the mirror glass. Needless to say it finally got fixed and works as it is supposed to. As some one else said it is the mirror motor that is the issue. Quote Link to comment Share on other sites More sharing options...
thirdgenlxi Posted November 7, 2013 Report Share Posted November 7, 2013 I had this same problem except the mirror would try to keep going and it would click. Well it lasted a week or so and died. You could still manually move and it would shimmy and shake while moving, but the memory part didn't work it was on the passenger mirror. My 11 edge only has 33,000 miles on it though. I took it in and had to argue with the moron tech at the dealership and finally got him to replace it. Well it went in to get done and the moron broke the mirror glass. Needless to say it finally got fixed and works as it is supposed to. As some one else said it is the mirror motor that is the issue. So why was the tech a moron? And what was the argument about? Just curious.... Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted November 7, 2013 Author Report Share Posted November 7, 2013 Thanks for the replies. I've never heard about waiting for the beep after setting #1 or #2. I'll try that first. Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted November 8, 2013 Report Share Posted November 8, 2013 Hey Tom When you hold it button for driver 1 and Driver 2, you will hear 2 beeps for each setting, not 1 beep for driver 1, and 2 beeps for driver 2. Just don't want you to be confused, whey not check it out in your owners manual, will be a lot clearer than my brief explanation. Joe Quote Link to comment Share on other sites More sharing options...
Tom Champagne Posted November 8, 2013 Author Report Share Posted November 8, 2013 You must have a newer model than my wife's 07. I've done the procedure as outlined in the manual and there are no beeps mentioned. Quote Link to comment Share on other sites More sharing options...
Wildjoker327 Posted October 30, 2015 Report Share Posted October 30, 2015 Were you ever able to get this fixed? I have an 07 Edge and I am having the same issue. I switched key fobs and it worked fine for about 2 weeks and then started all over again. Quote Link to comment Share on other sites More sharing options...
Reekola55 Posted November 3, 2018 Report Share Posted November 3, 2018 First off, I've been having the same problem with the side mirrors on my 07 Edge Plus for years. I've taken it to the dealership twice and both times I've been told they don't know what the problem is. Secondly, the 07 Ford Edge DOES NOT BEEP when holding down either button 1 or 2. I always see that suggestion offered and it has caused myself and apparently many others to hold those buttons waiting for the magic beep to happen. It won't. Ever. My guess is the motors are bad in both mirrors but I'll just wait for them to completely die before replacing them Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 4, 2018 Report Share Posted November 4, 2018 (edited) Seems to me that if the mirrors adjust using the mirror switch, they're still good. Q. Does the seat adjust when using the recall feature? Does the recall feature work if using the remote transmitter? Edited November 4, 2018 by enigma-2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 4, 2018 Report Share Posted November 4, 2018 (edited) BTW, are you using the correct procedure for an 2007? The press and hold fuction was correct for the 2009 (and possiblity the 2008 as well, I would have to check). Just to be certain, this is the correct procedure for an 2007. 1. Position the seat and mirrors to the desired position. 2. Press the SET control on the drivers door panel. 3. Within 5 five seconds, press the lock or unlock control on the Integrated keyhead Transmitter (FOB) and then press the 1 or 2 control on the drivers door panel which you would like to associate with the seat and Driver 1 or Driver 2 positions. 4. Repeat this procedure for the second Integrated Keyhead Transmitter if desired. Edited November 4, 2018 by enigma-2 1 Quote Link to comment Share on other sites More sharing options...
