Brucifer Posted April 7, 2017 Report Share Posted April 7, 2017 :worship: :worship: Hope they inspect the valve body & the solenoid assembly while they gut the trans. Drove home OK. Did the negative off - jumper to positive thing this morning. Shift slipping even more pronounced now. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 8, 2017 Author Report Share Posted April 8, 2017 Maybe the fluid level is low? Not uncommon for service shops to make this mistake. 1 Quote Link to comment Share on other sites More sharing options...
Brucifer Posted April 9, 2017 Report Share Posted April 9, 2017 Maybe the fluid level is low? Not uncommon for service shops to make this mistake. Actually looks kinda high, but being all clean and such, it's tough to tell. Followed the owner's manual instructions. Probably will go to my local mechanic tomorrow to have them check it as an outside opinion. It seems to be getting better as time and miles increase. 1 Quote Link to comment Share on other sites More sharing options...
lildisco Posted April 10, 2017 Report Share Posted April 10, 2017 Washed the Edge & CX7, drained the catch can & changed the oil on my CX7. Maybe if it stays warm enough the next few weeks, I'll put the summer tires on both vehicles. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 10, 2017 Author Report Share Posted April 10, 2017 How about some pics of the "twins"? Is your CX7 AWD? Quote Link to comment Share on other sites More sharing options...
lildisco Posted April 10, 2017 Report Share Posted April 10, 2017 (edited) 2008 GT AWD. I've had a lot of fun in that car. Probably done things i shouldn't have done, but it's been the 1st 4 cylinder that I've had that has had more that 160HP. Edited April 10, 2017 by lildisco 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 10, 2017 Author Report Share Posted April 10, 2017 Nice lookin' ride. Quote Link to comment Share on other sites More sharing options...
chefduane Posted April 11, 2017 Report Share Posted April 11, 2017 (edited) Got my new Viofo A119 Dash Cam installed. Nice clean install, I must say. Used a fuse tap on driver kick panel fuse #41 for the switched connection. However, I think I have something not set correctly on the cam as I did a test run and am only recording audio. The cam seems to be operating fine but when I remove the microSD card and try to read it on my pc, I only get the audio portion. Hopefully just a setting or somesuch. EDIT/Solution: The default video recording format for the Viofo A119 is .mp4. The Windows 7 default video player format is .mov. If you try to play the file with Windows Media Play or the Win7 default viewer you will only get audio as I did above. I downloaded an .mp4 player from CNet and opened the file with the .mp4 viewer and all is well. I suppose you could make the Windows player default to .mp4's but then all the .mov's would be messed up. Since I will only be reviewing the Viofo .mp4 files if I have a traffic incident, I intend to leave things as they are and use the downloaded .mp4 viewer to watch the dash cam files. Hope this helps somebody with the same issue! Edited April 11, 2017 by chefduane 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 11, 2017 Report Share Posted April 11, 2017 Replaced all four headlight bulbs in my MKX this evening. Used Philips X-tremeVision bulbs. Last time I did this, it took an hour. Today I backed the car outside (better lighting) and it too less than 10 minutes. (Still is a bitch though). One bulb has around 2" clearance, barely can get my hand I'm the socket. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 11, 2017 Author Report Share Posted April 11, 2017 (edited) Cool! Welcome to the X-treme Club And chefduane, glad you got the video up & running! Edited April 11, 2017 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
Spree Posted April 11, 2017 Report Share Posted April 11, 2017 Washed it today, first time pic with the 20% front windows. 2 Quote Link to comment Share on other sites More sharing options...
TowerMonkey Posted April 12, 2017 Report Share Posted April 12, 2017 It's been confirmed, I've caught the upgrade bug. Sometime next week I'll be adding LED DRLs to our SE thank to kmilliorn. After looking in the classifieds I count pass them up. Quote Link to comment Share on other sites More sharing options...
cmillz1331 Posted April 12, 2017 Report Share Posted April 12, 2017 Had to clear the A/C drain today...noticed the sloshing water "sand" noise in the dash last night. Last time it cost me a new A/C motor, hopefully I caught it quick enough this time. I followed MacT Ford Edge video on YouTube and it was perfect (although I never went under the car). Took about 2 min, but A LOT of water came rushing out. Hopefully all is well now. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 12, 2017 Author Report Share Posted April 12, 2017 yeah, idk what is better our system or the drainless systems they have in the Fusion & Taurus ... Quote Link to comment Share on other sites More sharing options...
akirby Posted April 12, 2017 Report Share Posted April 12, 2017 the drainless systems they have in the Fusion Drainless? Tell me more. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 12, 2017 Author Report Share Posted April 12, 2017 AFAIK, they have an Evap Rate sensor that keeps condensation from forming like it does in the Edge. No drain tube that I have discovered so far. Same with the Taurus. There are drain tubes galore to service sunroofs and cowls, but not the A/C. Am I mistaken? Quote Link to comment Share on other sites More sharing options...
akirby Posted April 12, 2017 Report Share Posted April 12, 2017 I don't know, I had just not heard of it. Now that you mention it I don't remember getting puddles on my Fusion. 1 Quote Link to comment Share on other sites More sharing options...
Spree Posted April 12, 2017 Report Share Posted April 12, 2017 Freshly waxed, love this thing! 1 Quote Link to comment Share on other sites More sharing options...
CARR142 Posted April 12, 2017 Report Share Posted April 12, 2017 Replaced brake fluid. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted April 12, 2017 Report Share Posted April 12, 2017 Freshly waxed, love this thing! That's what she said...... 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 12, 2017 Author Report Share Posted April 12, 2017 Points 2 your for replacing a rarely mentioned fluid Replaced brake fluid. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 13, 2017 Report Share Posted April 13, 2017 (edited) That's what she said...... Edited April 13, 2017 by enigma-2 Quote Link to comment Share on other sites More sharing options...
CARR142 Posted April 13, 2017 Report Share Posted April 13, 2017 Coolant flush. 1 Quote Link to comment Share on other sites More sharing options...
jrmynorcal Posted April 13, 2017 Report Share Posted April 13, 2017 I made my center 12V port switched via the ignition instead of always on. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 13, 2017 Author Report Share Posted April 13, 2017 Neat! Have you already mapped details in another post? If not, please consider doing so! Quote Link to comment Share on other sites More sharing options...
