cds71 Posted November 21, 2016 Report Share Posted November 21, 2016 Nick did you reset your tune back to stock before you brought your edge in for warranty work? Quote Link to comment Share on other sites More sharing options...
Nick Halstead Posted November 22, 2016 Report Share Posted November 22, 2016 (edited) Nick did you reset your tune back to stock before you brought your edge in for warranty work? Yes, reverted back to stock, Though that's not all you have to do. Just a simple flash still leaves you with every DTC available in the system. So you have to open Forscan and clear them. Though with doing all this, Ford can STILL see how many key cycles ago the PCM was "touched" they can't say if it was a tune to the PCM. I also logged almost 800 miles(lyft driver) after my flash back to stock. Edited November 22, 2016 by Nick Halstead 2 Quote Link to comment Share on other sites More sharing options...
tamugrad2013 Posted November 23, 2016 Report Share Posted November 23, 2016 Haven't done it yet but plan on spending a good chunk of my day tomorrow with my Edge. I am going to wash, dry, and wax it/ get all the bugs and grime off the grille/clean and polish the wheels/complete interior vacuum and cleaning/ and also cleaning, greasing, and reinitializing the vista roof. Probably will change the key fob battery as well. I did get her inspected today, and also changed all of the wiper blades prior to inspection. I do hope I can get all of this done. I am going to start around 8:00 am. My car has been absolutely filthy since this last heavy rain in Odessa about three weeks ago so she needs a lot of TLC. I post and update tomorrow. Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 23, 2016 Report Share Posted November 23, 2016 (edited) Lately noticed an unusual build up of acid on the positive battery terminal so decided to clean it, but it only re-appeared just as bad a couple of weeks later so decided to remove the terminal & do a thorough cleaning only to find out the batter case was cracked right under the terminal connector & the terminal connector badly corroded. A battery case cracking like this is something new to me. The battery was 14 months old only & the car still started fine. So got a new battery, under warranty, and installed a new terminal connector, thankfully for the Edge/MKX it comes separately without the cable & cheap (~$12/-). Edited November 23, 2016 by omar302 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 23, 2016 Author Report Share Posted November 23, 2016 Wow. This battery original to the MKX? Possibly overtorqued terminal, or just a weak point in the case? Glad you could get it done under warranty. Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 23, 2016 Report Share Posted November 23, 2016 It was the 2nd replacement since car rolled off the factory. In our area batteries usually have a life span of 1-3 years only due to our extreme summer temps & high humidity. The crack seems to be from the case deforming, probably heat related rather than mechanical torqueing. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 23, 2016 Author Report Share Posted November 23, 2016 Did you put in a Group 65 battery? Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 23, 2016 Report Share Posted November 23, 2016 Yes. That is the stock size for the 2011-2015 MKX. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 23, 2016 Report Share Posted November 23, 2016 Yeaaaa, when I used to get a bug up my ... I used to run it through the car wash first, just to get a head start on the process. At my age now, it's much easier to just drop it off at the detailer and pick it up at the end of the day. That way you can drink all the beer you want and still get it clean. HA. 1 Quote Link to comment Share on other sites More sharing options...
tamugrad2013 Posted November 24, 2016 Report Share Posted November 24, 2016 I find it therapeutic. It looks amazing and the sun roof closes now in 8 seconds down from 14 seconds. Cleaned all the railings with some paint brushes and lubed it up with WD-40 Silicone Spray. Wish I would have taken a before picture. She was awful looking. Quote Link to comment Share on other sites More sharing options...
arabski Posted November 24, 2016 Report Share Posted November 24, 2016 ...I just sold mine... 3 years and 59k miles - reliable and rewarding machine... but I won't probably buy another Ford after those annoyances that cost so much to fix (vista sunroof, shift to park, A/C button...). Good thing I never had any major failure and the car is (if you dont count the roof that does not open) in perfect shape. A new owner should be happy for at least until the drivetrain warranty runs out. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 24, 2016 Author Report Share Posted November 24, 2016 What is your replacement ride, arabski? Post some pics! Quote Link to comment Share on other sites More sharing options...
chefduane Posted November 24, 2016 Report Share Posted November 24, 2016 Whoo Hoo! Thanksgiving day and The Chef is not doing the turkey. Mom-in-law is in town and she is cooking! Got up early and swapped out the wiper nozzles. Driver side was all messed up and spraying all over. Decided to do both of them. You guys were right, both of them were brittle and cracked. The passenger side tip broke off in the tube of the 'T' connector so I had to carefully remove the broken up remnants. After that both went on fine and got the hood liner up also. I strongly suggest getting a set of nylon interior panel pullers from Harbor Freight for pulling the keepers off the liner. Makes things a lot easier and doesn't mess up the liner. While I was at it I also installed an AEM Filter Minder #30-5111. I am a big fan of AEM Dry Flow Filters and the little filter minder is a little gadget that tells you when the filter is clogged. I usually clean the filter every other oil change, but I saw Mact's vid on in and decided to get it. Easy install. Now it's Couch Time and watching the continuing miracle of the Cowboys! Happy Thanksgiving to All! 1 Quote Link to comment Share on other sites More sharing options...
haedgy Posted November 27, 2016 Report Share Posted November 27, 2016 Cleaned my leather seats, man that light interior gets blue jean stains fast! Have leather sealer on the way, till then keeping them covered. Modded my puddle lights. Now they are nice and bright! Was fairly easy job to boot. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 27, 2016 Author Report Share Posted November 27, 2016 (edited) Leather berber is the answer Any pics with the new puddle lights in place? EDIT: N/M, just saw your thread http://www.fordedgeforum.com/topic/21641-2016-edge-puddle-light-led-mod/ Edited November 27, 2016 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
PrinzII Posted December 23, 2016 Report Share Posted December 23, 2016 I know it's been a while but my focus has been to get my 2017 list of things done for the Edge starting with replacing the Yokohamas with the new Pirelli Scorpion Verde Plus. #wtfyokohama 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 23, 2016 Author Report Share Posted December 23, 2016 Welcome back from the MIA zone Did you ever get an LED light bar put on? Quote Link to comment Share on other sites More sharing options...
CincyKyle Posted January 1, 2017 Report Share Posted January 1, 2017 Tinted windows and painted the grill Tuxedo Black! Quote Link to comment Share on other sites More sharing options...
CincyKyle Posted January 1, 2017 Report Share Posted January 1, 2017 Here is the pic that was supposed to go with my comment! 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted January 1, 2017 Author Report Share Posted January 1, 2017 Looks great Quote Link to comment Share on other sites More sharing options...
Burrcold Posted January 2, 2017 Report Share Posted January 2, 2017 Looks really good! The painted Ford emblem looks good too! Quote Link to comment Share on other sites More sharing options...
Vhalen50 Posted January 4, 2017 Report Share Posted January 4, 2017 (edited) Here is the pic that was supposed to go with my comment Youre from cincy? Me too. Im trying to get my 2016 titanium front grill painted, and possible smoke my tailights, but the only shop i could get a realistic quote for was nearly 400 bucks. Where did you get it done? Edited January 5, 2017 by Vhalen50 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 4, 2017 Report Share Posted January 4, 2017 Whered you get it done? "Whered"? Whered you come up with that word? lol 1 Quote Link to comment Share on other sites More sharing options...
chefduane Posted January 5, 2017 Report Share Posted January 5, 2017 Whered is irrevelent. As long as you gitterdun. Quote Link to comment Share on other sites More sharing options...
mex3000 Posted January 5, 2017 Report Share Posted January 5, 2017 Had gloss black vinyl wrap on grille, matte black wrap on Ford emblems, and plasti dipped the fog light assemblies. 1 Quote Link to comment Share on other sites More sharing options...
